I got up my courage this afternoon and decided to try to solder the air feed tube to the cylinder and then plug the two valve holes. The air tube went fairly well. I melted solder over the back, set it into the intake hole, and then heated the assembly until the solder melted. It seems pretty solild, although there was solder that ran out onto the cylinder that needs to be filed off.
For the two holes I just cut off some pieces of solder, laid them over the openings, and heated until they melted. Of course I had some solder run into the valve bore, so I needed to drill it loose and then run the chucking reamer into the bore again.
Unfortunately one of these plugs seemed loose, as it popped up when I ran some air into the bore to blow out the swarf. So I had to drill it out and redo that one.
In retrospect, I think a better plan for the valve holes would be to drill them larger on the exterior and fabricate a plug that could be sweated on. Alternatively the cylinder could be made larger so that the hole could be tapped and plugged with a screw. I considered this, but there isn't enough depth to the holes for that to be secure.
I still have some nuts to make, some rods to thread, joints to loctite, and setscrews to cut down before reassembly for the first trial run.
