Mrs Maryak's Mansion
The House is looking great Bob.....whats the ETTF? ;D
We want pictures of the shop being created! ;D
stevehuckss396 said:
Are your panels producing electricity or hot water?
Steve - Hot Water with a gas booster for the odd gray day. ::)
Dave - The date we were given is 20 Aug 2009 and so far no update on this.
Best Regards
We are not sure what will be next
I'd guess that electrical fixtures (outlets and switches), moldings, and hanging internal doors could start now. If it were mine and DIY, I'd probably paint the ceilings. Here we normally use a different paint (thicker, less drip) for ceilings as opposed to walls.
I assume they will finish painting the walls before installing flooring.
Hi All,
Well the weekly pilgrimage showed us "What's Next"
The house was locked up. :eek:
Got a key from the rep in the display village and had a look.
Kvom - You are/were spot on. Inside we found all the internal doors and the material for the skirting and architraves.
Locked out.
Skirting/architrave materials.
Kvom - As you also said, things have slowed down considerably.
I will be laying the floor myself so I have sent a drawing to the supervisor of the areas to be floored and they will only tack the skirting in so I can remove it and lay the floor before securing it properly.
Best Regards
View attachment Floor timber.pdf
Bob: Is the interior finish material solid wood or engineered wood? In Canada (except for the mansions) doors, casing, baseboard etc are all made out of sawdust, shavings, paper and glue and moulded to shape.
Bob,
Here we have baseboards that go along the bottom of the walls (skirting?), and then may have quarter-round molding at the bottom of that. If that's your system as well you can leave the baseboards as is, lay the floor with spacing , and then cover the gaps with the quarter round.
If you are laying tile, you do not want the skirting in place, as it's almost impossible to keep the mortar off, and it's a pain to tape it all off. (Ask me how I know).
For a floating floor, I can also recommend that the underlayment be the kind that comes in rolls and is duct-taped together. My upstairs floor over the garage had a rubber pad glued under the laminate, and when cutting it generated a rather foul dust.
Best of luck
Kirk
Stan,
It's the same in Oz. We paid an additional $2500 to have solid wood. The timber is Meranti.
Kvom,
The idea is to do away with the 1/4 round on the skirting, (baseboard), as we don't like the look. The wet areas and kitchen floor/splash surround will be done by professional tilers. Your underlay method of rolls is the one we will use, but under the underlay is a plastic damp proof membrane also taped together from rolls.
Best Regards
Sorry Bob. That was rather uncouth of me. I should have noticed the title of your thread!
My house, built in the 1970s is all solid mahogany trim with stain and varnish. I much prefer it to the bland off-white paint in the new houses.
Kvom,
Thanks for that, I will look into it and see if there is such an underlay here.
Stan,
I don't think you were uncouth. If I could have got it past Galina I would have had the engineered wood! Her argument is our current unit has stained and varnished doors, skirting and architraves and our new home must not be of a lower standard.
Galina has an excellent eye for interior decoration and very good taste whereas me........ ??? ??? ??? ???
So in the interests of harmony, matrimonial bliss, etc., etc., etc. There we are.
Best Regards
.... and after all, it's only money! Might cut into the lobster budget a bit tho' mate.
tel,
Even if I'd gone for the engineered wood solution, I doubt we would have saved enough to order Rock Lobster.
Best Regards
Bugger! Looks like it's a knob of devon and a loaf of Aldi whole grain then!
tel,
As long as it's discount bread and fresh fritz, (devon).
Lots of progress this week but the rep left the key at home so we couldn't get inside when we would really have liked to. ::) ::) ??? ???
The outside paving and stormwater drainage.
Looking through kitchen window.
Looking through Bed 2 window.
Looking through rear family room door.
Looking through master bedroom window.
At the moment we are happy campers.
Best Regards
tel,
You got that right. :eek:
We managed to get inside, the skirtings and architraves are finished, the tiles for the wet areas and kitchen have been delivered.
Here's a few shots
The 2nd bedroom BIR.
The kitchen
Hall linen press.
Laundry linen press.
Surveying our domain.
View down the street.
Stay tuned for next weeks progress.
Best Regards
Hi All,
kvom sure was right when he said things would slow down. Last week progress zero, zilch, nil, nothing. This week a bath half installed and we got our first real look at the front of the house without a rubbish skip and toilet in the way.
Ah well while they are not working, we are not paying so seems fair enough.
Best Regards
Hi Bob, many years ago I plumbed for a living and I've never seen a tub installed quite like that. Most tubs had skirts which supported the outside edge. I assume they will be building a framework around it but it seems like it would have been better to do that first to get everything level. Another thing that wouldn't fly where I live (nothern Ohio, cold snowy winters) is the pipework coming in from an outside wall. On a winter day the pipes could very well freeze. My wife and I had a new house built almost 8 years ago now and after all the work, confusion and moving we are enjoying very much. I'm sure you and the wife will do the same. It's nice to have a photo documentation of all the work.
gbritnell
I agree that the plumbing looks strange, but since we can't see the entire space perhaps they had to make some compromises.
I do like the kitchen cabinets; looks like a very convenient setup.
George and kvom,
The pipes on the wall are for hot and cold plus a hand held shower for use in the bath. The bathe surround will be tiled and I can only assume some framework will be required to support the bath and the tiles. One thing that is not a problem here is the pipes freezing.
Galina and I are very pleased with the kitchen so we are glad you find it convenient. A small boast, it's my design and whilst it looked OK on paper, I can't tell you how relieved I was at Galina's reaction when she saw it in the flesh.
Thanks for following along. My hit and miss is more miss as we are getting closer. Last week was a short week and a lot of time was spent interviewing Realtors to determine who we will have sell our unit.
Best Regards
