Lagerbolzen
New Member
All very interesting life experiences chaps, but could we perhaps keep loosely on the model ignition theme.
I have found that depending on whom you talk to about plasma you get different answers, everyone has an opinion right. I was taught that plasma is super heated gases at or above 5,000 deg. F. high enough to create free electrons. But if that's the case then what about neon lights and such? In RADAR we used both klystrons (basically a metal tube) & magnetrons (WW2 British invention but finished by MIT) for the final amplifier but, only the klystron becomes radio active because of it's design it produces x-rays from the high voltage.Well Ray, Sorry to hear of your shocking experience!
I hope my explanation of the ignition is somewhere close to what is really happening... it is a compilation of all my varied experiences of "sparks" - and deducing what is happening...
Curiously, when lightening strikes, the thunder is the sound of the shock wave of the rapid collapse of the fine thread of expanded gas from the arc. And - please correct me if I am wrong? - a plasma is created in every arc where the current flows in the ions? (even in the corona from HV electrical kit). - The ions make-up the plasma (I think?). The temperature of the plasma is easy to see as it is white~blueish... 2000 ~5000 deg.C? I.E. the "visible spark" of light emitted from the electrons leaping to higher energy levels from electrical energy input, then falling back to their earlier lower energy levels while emitting (EMR) radio waves and visible light. (I think a high enough voltage emits X-rays?). And a plasma of ions from air and fuel molecules will explode (spontaneously combust) as the ions re-combine as different molecules (exhaust gases) and release their chemical bonded energy in the process. This is the ignition that starts the flame front that travels in the combustion chamber.
If insufficient arc energy is input, the chemistry of combustion fails...
In circuit breakers, the arc is generated immediately as contacts separate (incredibly high electrical stress when the gap is near to infinitely small.. well molecular dimensions...) and continues until the voltage reaches zero (as in AC breakers) or adequate arc cooling occurs to prevent a continuous path of ions (plasma) between the contacts: I.E. some resistive gas is put in the place of the conducting plasma. This plasma-cooling and substitution with interposing fluid (resistance) is sometimes generated by external means, and sometimes by a gas explosion generated by the rapid heating of the insulating medium. (e.g. oil or gas).
All good for the soul. Using the body as a conductor is never good for the body or the soul!
Cheers!
You have to remember that, that ignition was for automotive racing and at full power it draws 48 amps charging the coil! It will ignite a lean mix or rich mix just as easy as a stoichiometric mixture. Yes it is hard on sparkplugs but, when I tested it on my truck I turned the power down to about 66% and it was ok. To give you some idea of the power, if by chance a cylinder has a air/fuel mix in it, is at or near TDC, and it just happens to line up with the rotor, and you turn the ignition on (which causes a spark) half the time it will start the engine!!! So it's not for model engines. LOL I do have a CDI that will work down to 0.400ma that works nicely with model engines and will be presented here later as a kit.Thanks Ray, Interesting! That is a hell-of-a-powerful spark if you are getting metal transfer! I would have thought the metal ions are disruptive to the wellfare of the engine internals... as well as creating a very short life for the spark-plug! Is there not too much spark current? - Especially for models where spark-plugs are relatively tiny? The Champion Engineer that I advised me on plug selection testing and results, explained that the purpose of the arc is to ionise and ignite the fuel but not to erode the plug contacts, which is why they recommended copper core (for cooling the electrode) and platinum tipped plugs - which were new technology in the 1980s for longer service intervals. (Aside: Not really "new" technology, but a move away from the GM and Ford policy of "cheapest" - that gets the customer to return to the dealership most often for cheap servicing - so Dealers have more contact for selling new cars..., and the cheap servicing doesn't dissuade the customers from using the dealer for servicing. The Japanese manufacturer's marketing in the late 1980s was for MINIMAL servicing... (only annual) so customers come back to the dealers when they are more likely to see a new model that makes their car look dated... therefore buying the next year's model!).
Interested to hear more...
Yes it true the plugs can burn away real quick, the plugs won't fire but they're so hot that the nitro will still ignite, they end up working like a glow plug. Nitromethane is a really weird solvent, yup that's what it really is, pour it on the ground like concrete and hit it with a hammer and it will ignite. But when it is under compression like in an engine it is very hard to light, it needs heat, which is why they usually start the engine on gasoline or alcohol depending if N/A or supercharged. Doug Doucette a local TA/D racer here was working with me on my ignition and he ran a 500CID N/A nitro burning engine, he showed me a bunch of burned plugs and the race data. You can see from the data when a plug burned away and either finished the run or went cold from the fuel. Years ago when they ran straight magnetos and fixed timing one of the problems was they couldn't really control the combustion temperature so they ran hot and when they finished the run they would throw a switch which shorted the mags out but, if there was any fuel left in the system the engine could/would keep running until it ran out of fuel. This caused several accidents when the engine would refire and the car would run into someone/something. Today they use an MSD ignition system usually the 'Grid System' and can control the timing for the whole run and usually they do the same as me and we pull timing out in third gear or the top of the run for them. The engine and sparkplug temps get to high and pulling timing out cools those temps just enough to keep detonation down and for them burning plugs but it still happens a lot.Ray,
I once heard that a top fuel dragster burned off the spark plug electrodes almost immediately on the start and dieseled the rest of the way down the track-true? Also a possible factoid that the dragster engine only turned about 800 revolutions for a 1/4 mile run, the arithmetic seems to sort of support this?
So I'm finally getting to solder up my scope kit. It's a JYE Tech DSO 138 Oscilloscope DIY Kit, it's their older model that's still available on the internet at Amazon for $40.00 CDN. I've had it for a while and it's obsolete, their new version is the DSO 138mini Oscilloscope DIY Kit and it is cheaper. It can go up 200Khz and 50vpp so for what it will be used for here, it is more than enough, well we'll see eh. Here is the link to it's web page DSO 138 Scope. All the surface mount components are pre soldered so it's just the through hole stuff to solder.
View attachment 128863View attachment 128864
I also bought a clear plastic box/case for it, safer right. It's a single channel with some neat features. I wouldn't mind trying their DSO 68 kit because you can connect to your PC and use their software to display the waveforms. I was surprised to see that they we're using a STM32F103Cx processor it's actually a mid line 32 bit ARM processor so it's got some nice specs. Anyway I'll talk more about this and let you know how the soldering went. Oh it needs a 9 volt power supply.
Ray
Yes I drove top fuel dragster and funny cars but not the modern day ones. Even back then on a hard run the plugs would be burned off at the end of the run. Looking at them you could tell how bad the rest of the engine was. Burned pistons were common . We didn’t replace everything every run like today but often enough. Today al of them have onboard data logging so all you have donis look at the data and interpret it. Driving down the road we often played calculator numbers as these were relatively new devices. It doesn’t take long to arrange number against time to get how many revolution the engine turns knowing tire size and gear ratios. Total run life was about 3 minutes if all 8 pistons survived. Even back then cranks lasted only 20 runs or so for the very best that were about 5 grand then. Aluminum rods were good for 5 runs you could send them back for reconditioning once maybe. They have sedated cap surfaces so you can’t practically do them yourself few shops had tooling to do this. They often were out of round of wrist pin holes beat up so rods were expendable. If you were lucky a spun bearing crank could be repaired by a good crank shop. Cranks get twisted too John force’s tuner put onboard testing device Ed snd proved this years ago. Even cams twisted and caused valve issues. That’s why gear driven cams became standard. Vale springs went from 300 pounds on the seat to way over 800 pounds open. Push rods were made custom tapered with varied wall thickness an incredible expense back then the entire drive line became custom made from exotic materials. The rear axel tube now is bigger than a big guy arm made from 300m mar aging steel even it gets twisted. Gears are custom made too. There are no junkyard pars on these cars today. Funny car bodies used to be about 4 grand now they are carbon fiber and 30 grand or more add about 30 more grand to mount it few are painted but wrapped now days. Even nostalgia cars are very expensive to run. I forgot the blowers. They start about 30 grand. The rotor strips last a couple runs. They can take over 10000. One thousand hp to drive there are a few blower synos often using s supercharged alcohol motor to drive them for testing. It’s amazing the belts hold up for a single fun. They are custom made too using carbon fiber material. My street rod went 30k miles on a standard 8 mm belt the pulleys were about worn out from road dust but the belt was ok. This was an old school race belt that would last ten runs in the old days. Blocks and heads ar carved from a solid block or custom forged block of aluminum they don’t use coolant they have replaceable sleeves allowing various bore sizes to be used there is a lot of fechnogy in these cars now that wasn’t even dreamed of 30 years ago. It’s like our govt money is no object. Some time take you trusty calculator any figure out how much money weighs. A new $100 bill weighs about how 1 gram . A simple way is to pose the question on the kntrernet you can get the number of semi trailers it would take to haul the proposed budget away. It’s pretty amazing.Ray,
I have an old Phillips scope a PM3302 I bought it years ago. It's old and almost worn out but it's still kicking and the storage part of it usually works LOL. I have 2 1x-10x but yah I should get some attenuators. I hacked a old probe and put a precision 1 meg resistor inline, it works but don't ask about calibration or tuning it LOL. Thanks dsage for reminding me.You'll have to make some attenuators for the input of that scope. Many things you'll measure in an ignition system are over 50v. No sense going by the way of your China coil with the scope.
Doug Doucette and I both agreed quick is never quick enough, you get use to the G's and speed and then you want more. So 'how fast can one afford to go'Yes I drove top fuel dragster and funny cars but not the modern day ones. Even back then on a hard run the plugs would be burned off at the end of the run. Looking at them you could tell how bad the rest of the engine was. Burned pistons were common . We didn’t replace everything every run like today but often enough. Today al of them have onboard data logging so all you have donis look at the data and interpret it. Driving down the road we often played calculator numbers as these were relatively new devices. It doesn’t take long to arrange number against time to get how many revolution the engine turns knowing tire size and gear ratios. Total run life was about 3 minutes if all 8 pistons survived. Even back then cranks lasted only 20 runs or so for the very best that were about 5 grand then. Aluminum rods were good for 5 runs you could send them back for reconditioning once maybe. They have sedated cap surfaces so you can’t practically do them yourself few shops had tooling to do this. They often were out of round of wrist pin holes beat up so rods were expendable. If you were lucky a spun bearing crank could be repaired by a good crank shop. Cranks get twisted too John force’s tuner put onboard testing device Ed snd proved this years ago. Even cams twisted and caused valve issues. That’s why gear driven cams became standard. Vale springs went from 300 pounds on the seat to way over 800 pounds open. Push rods were made custom tapered with varied wall thickness an incredible expense back then the entire drive line became custom made from exotic materials. The rear axel tube now is bigger than a big guy arm made from 300m mar aging steel even it gets twisted. Gears are custom made too. There are no junkyard pars on these cars today. Funny car bodies used to be about 4 grand now they are carbon fiber and 30 grand or more add about 30 more grand to mount it few are painted but wrapped now days. Even nostalgia cars are very expensive to run. I forgot the blowers. They start about 30 grand. The rotor strips last a couple runs. They can take over 10000. One thousand hp to drive there are a few blower synos often using s supercharged alcohol motor to drive them for testing. It’s amazing the belts hold up for a single fun. They are custom made too using carbon fiber material. My street rod went 30k miles on a standard 8 mm belt the pulleys were about worn out from road dust but the belt was ok. This was an old school race belt that would last ten runs in the old days. Blocks and heads ar carved from a solid block or custom forged block of aluminum they don’t use coolant they have replaceable sleeves allowing various bore sizes to be used there is a lot of fechnogy in these cars now that wasn’t even dreamed of 30 years ago. It’s like our govt money is no object. Some time take you trusty calculator any figure out how much money weighs. A new $100 bill weighs about how 1 gram . A simple way is to pose the question on the kntrernet you can get the number of semi trailers it would take to haul the proposed budget away. It’s pretty amazing.
byron
We went to the point of economics limit. Much of drag racing was match races depending on number of cars an program to be run. The name of the game was to make all of your laps or runs to get paid. Often the two quickest came back for a final round for some extra money. It forced you to run hard snd not breaknparts. Often the rule of the line was you had to take a green light to get round money. If you knew your car was in trouble you might get away just taking the green and hoping you didn’t do any further damage. I did this several times. One afte the clutch exploded. Parts were flying all over but as I backed up I saw the competitor push truck sitting on top of crushed starting lights I took the green hoping the rest of the drive line didn’t end up in my lap. Luckily it didn’t. I was crazy back then invincible as they say. We borrowed a complete clutch and with the next round guy crew changed it all out. I took a guess on adjustment and wound up winning the race. It basically paid for the damage. In 5 years we lost only 2 rounds but saved several with only minor damage. The extra round usually paid for the damage. Poor use of economics trading a dirt dollar bill for a clean one. Not quite but you get the idea. Lots of pistons were burned early ones were of weldable material so I welded them up and remachined the ring grooves. Pistons were about $200 each so an extra run or two allowed purchasing new ones . I did them for other guys too so I made a few dollars on the side. We didn’t have aluminum blocks and heads back then do we were slways on the lookout for a used motor. Or pair of heads. Few other parts were used. I salvaged a couple blowers that I sold as rebuilt or cores. Yeah scrounging was part of racing back then. I worked in a hot rod machine shop so I had some advantage of not having to have others do work for me. .Thanks for all the info re drag engines. I used to subscribe to Hot Rod magazine just to read about the engines and technology but it got so far from what a shade tree mechanic or someone on a small budget could do I quit the magazine.
NASCAR used to be interesting but now the engine/car specs are so tightly controlled there is virtually no difference car to car, purely a drivers race,which was the intent I guess. I used to enjoy the few years of CANAM racing in the 60's where you could run what you brung, resulted in some interesting cars like the vacuum cleaner of Jim Hall(?).
I apologize and think we have hijacked this thread too far, maybe start a new one but don't know under what heading!
Well I found what your looking for but you won't like it. The info below was taken from the National Center for Preservation Technology & Training and it is from a POD cast that you can read or listen to: quadricycle-questions-with-mose-and-andrew.Does anyone know about igniters, as used by Henry Ford on his Quadricycle? I'm close to finishing a 1/4 scale model and have had some advice on the ignition but I'd like, if possible, to keep it as authentic as possible. I'm not looking for performance or even long running times, if it runs for 30 seconds or so at a time then I'll be well pleassed.
Brian
Well Done Ray. Looks like you're onto a winer there. Great Stuff.So I'm finally getting to solder up my scope kit. It's a JYE Tech DSO 138 Oscilloscope DIY Kit, it's their older model that's still available on the internet at Amazon for $40.00 CDN. I've had it for a while and it's obsolete, their new version is the DSO 138mini Oscilloscope DIY Kit and it is cheaper. It can go up 200Khz and 50vpp so for what it will be used for here, it is more than enough, well we'll see eh. Here is the link to it's web page DSO 138 Scope. All the surface mount components are pre soldered so it's just the through hole stuff to solder.
Ray
I believe my set of plans for Leon Ridenour’s version of the kitchen sink engine outline a reasonable facsimile of an igniter. As this engine was the forerunner to his development of a workable internal combustion engine, and having some similarities to the Quadricycle engine, perhaps this type of igniter would suit your purposes.Does anyone know about igniters, as used by Henry Ford on his Quadricycle? I'm close to finishing a 1/4 scale model and have had some advice on the ignition but I'd like, if possible, to keep it as authentic as possible. I'm not looking for performance or even long running times, if it runs for 30 seconds or so at a time then I'll be well pleassed.
Brian
