Interesting to hear these stories of injector work. Thankyou all!
Minh Thanh: Well done on making an injector. Watching your video clip I saw a single spray from the nozzle - looked pretty good to me: the classic cone spray. But I think that a "real" injector will be operating normally at much higher pressures than your plastic pipe can manage. (>30bar? >2000psi?). Steel pipe on "real" high-speed diesel engines is used to withstand the pressure (pulse) developed by the injector pump - which in turn opens the valve in the injector and allows the spray. The pressure in the cylinder is at anything up to 23 bar when the injector operates, so you have to overcome this pressure before the spray can happen. Check you design calculations to be sure your injector can withstand such pressure.
But (from my poor memory of 50 years ago) when as an apprentice I was shown the job and tested a box full of used injectors (yeah, made me an "ex-spurt"!), the "spray" was more of a conical cloud of diesel oil. I was using a Lucas CAV Hand-pump tester for diesel injectors. A very simple device comprising a hand pump, pressure gauge, steel pipe-work, reservoir for fuel oil, and mounting to connect a single injector.
See this for a modern version: Beta Diesel Injector Test and Calibrating Hand Pump - 960PMC
The idea (keeping hands, eyes and clothes away from the spray) being to check with a single pump stroke that the spray was conical against a plate with a cone drawn on it, no drip from the injector, and the injector opening pressure exceeded some value on the gauge. Maybe Alex 1952 can enlarge on details as I am sure from his 40 years experience he knows the kit I used for about 1 hour.... But in that hour I was told that if I put my finger over the injector and pumped, the oil would inject through the skin into my blood stream and kill me. Or at least I would be very ill and probably loose the finger as the oil would kill the flesh... So Alex is exactly right with his advice.
Take care. Wear Protective goggles, to keep splashes from your eyes, have a fire extinguisher within reach as Oil-mist clouds are highly inflammable, ensure no ignition sources exist, and wear appropriate hand protection as the oil can cause dermatitis (bad skin). There is a similar safety warning on this page, which should teach you anything the contributors above have not already mentioned: Diesel Tractor Injector Testing and Overhaul
Enjoy!
Enjoy!
