Jack3M
- Jul 11, 2017
- 294
- 140
Okay, after analysis; the depth I cut was 0.070, determined by the calcs above. That was one extreme, the min was 0.067. Will that .003" be enough? I will admit my gibs need tightened, which I can do now that the thing is over. Also, I did it in 3 different sittings, so I could have goofed somehow. Obviously the teeth are cut too deep, no flat on the top. Also, at one point early on....had to remove the cutter and get relief, and used the previous cuts to align the cutter to same tooth. Then started back over in the same place as originally, the alignment was not off at that point, but that was not a good thing to do regardless, at that point I had no other choice. The relief was necessary because of the small diameter material chosen for the tool 0.5". Considering making a new one from some 1.25" tool steel I have on hand. Hate to waste it on a 32DP 14.5. Not a common size, but still overall less expensive than the involute cutter sets.
As in part two of the video, each cutter tooth does a cut on a different part of the gear tooth.
Karl, I like the idea of the sandwich, and will combine that with some sort of arbor that will clamp over be a tolerance fit. Even wiih loctite, it loosened and had to fix that.
So many things could have been. Probably a combination (comedy) of errors? Let's see if I can screw up the mating gear today while I await a new countershaft gear.
