Mastiff lc mason engine REDO .
Hi All !
An update
Small project within this project
I put some temporary parts together, and saw if the cutting process worked as I intended.
Do you have the equipment that you can rotate the gear?
I made my own equipment for rotate the gear. In the video just a few simple parts so I can see how it cuts
I'm having trouble and trying to solve it
- In the video the cutter is above the workpiece and there is no place for me to mount the equipment on the machine (lathe)
-->> If I move the cutter below the workpiece I need to make an extension for the slide and I also need to make sure the cutting direction of the teeth is correct, L or R
Without the rea; thing with the real lathe it is very difficult to see how to advise. It looks like it should be relatively simple
I just got "freed" from the things posted in the break room, that's really happy. Thanks Admin ! 😍
Hi All !
An update :
I need to make a shaft to couple with the pump part to determine the position...and drill holes...
Everything is pretty good, the coupling will be made of steel - in the picture is aluminum
