I have started my build of the Rupnow Vertical IC Engine. Figured I'd start my own thread to cover my build vs adding to Brian's thread. It will probably take me a lot longer to build then Brian took.
I ordered most of my materials from McMaster Caar - the cast iron bars as well as the rectangular aluminum stock - downside is have to buy 1ft most of the time. I also purchased the bushings from McMaster though they are a little longer then required by a 1/16" in most cases. I figure it was pretty simple to just face off the end to get the right length. I think they were between $0.50 and $0.60 a piece - so I got a couple extras just in case I screw up
I figured I'd try and do the head first - figuring if I could accomplish that I'd be able to get the rest of the project built. To be honest it took me 3 attempts to get it right. The first one got majorly delayed when the head of my Bridgeport seized up and required a rebuild. While it turned out that the actual cause of the "seizure" was a dog point set screw for aligning collets had been removed by a previous owner then placed in behind another set screw to fill the hole. It worked loose and had been slowly rubbing off and when I had the mill running at high speed it fell out and jammed between the spindle and spindle nose. Once I got the mill back up and running this past weekend, I managed to ruin the first head. I was completely fixated at entering the bolt hole pattern into the DRO and didn't realize that I was 90 degrees out on the start of the first hole. So you guessed it the bolt hole circle was not in the correct place. I also missed the counter bores for the valve piece when I was doing the bottom of the head. The drawings are pretty busy, one really needs to concentrate on reading the fine print (not mocking the drawings - just a complex piece with a lot of information in there)
The second attempt suffered from me trying to be cheap - using only the barest minimal size to hold in the lathe and then attempting to part of the extra 1/2" of material after completing the first end. Figured hey, 1/2" of 2" aluminum bar that could be used for something else. So I thought that I'd part it off. Not wanting to leave chuck marks in the work piece it wasn't super tight in the chuck.... dumb, dumb dumb - parting tool grabbed and ripped the piece out of the chuck. Hangs head in shame.
The third time was a charm. It did get a bit hairy at the end. I don't have an angle vise so I had to think of another way of cutting the angle. I also don't have a chuck for my rotary table though I do have one on the end of my indexing head but that creates a very tall stack. Tall means less rigidity. I simply used a v-block with the head on parallel to drill and counter bore all the holes on both sides. Then I used a left over piece of round stock with the 3 holes drilled and tapped to hold the head. I then tilted the Bridgeport head appropriately and machined off the angle area. Not thinking ahead, I didn't take into account the amount of clearance needed to move the table to the left to get access to the tap drill bit required for the 10-1 mm tap. With the vise in the middle of the table I ran out of left travel, not wanting to reset the vise etc I simply loped off the drill bit and resharpened it. It got the job done, hole is drilled and tapped. In hind sight, I probably could have held the drill bit in a 3/8" collet and not needed to cut it off - I thinks only a 1/64" less then 3/8". I always think of the easier way - after the fact. I did make one minor mistake when I drilled the hole for the spark plug I went through and hit the other side of the slot (see last image). I don't think it will harm anything.
Some valuable lessons for myself. Really wished I hadn't screwed up on that second head but learned its better to just sacrifice small pieces instead of trying to save a few cents. Better to think twice and double check all the operations before committing to a setup.
Thanks Brian for providing the drawings. Looking forward to building out more of this engine.
Looking for a bit of advise as well. My thought on doing the main body of the engine was to square up the ends of the aluminum. Put in all the holes and so forth ending with drilling the 1" holes. Then go over to the bandsaw and removing the bulk of the waste and then back to the mill to finish up - am I being cheap or should I just mill the excess away?
