I got a chance to get back out to the shop late Thursday afternoon. The first thing I did was make myself a pouring shank for my crucible. This one is just simply a ring to hold the crucible and a small vertical riser and then the handle. With the ring correctly sized and shaped it seemed to hold the crucible extremely stably so I decided to forego temporarily a locking mechanism to prevent the crucible from falling out (aka I was in a hurry and wanted to get on with the show
On Friday morning after getting my "apprentice" working on his project - he's building a Jan Riders' coffee cup Stirling, I started getting ready to create a new mold.
Some of my issues with creating the mold stemmed from the fact I didn't really have a way of lifting the cope off the drag perfectly vertical because I had no way of gripping the cope. Therefore I added some draw pulls to the sides of the cope and drag to make them easier to move. This worked well *except* I put them 90 degrees to the lock between the cope and drag which gives better grip but means that I can't set them on edge to clean out loose sand. Will adjust before next go round. I need the handles because in this scenario there is 50lbs of sand in each half of the mold.
Because I had a lot of problems the last go round with the hub that I added to one side of the pattern for holding while turning. While the true problem was probably not being able to lift straight up (no handles last time) I decided to ram up the drag with this half of the pattern instead. It worked. I also used a thicker runner to feed the pattern, not sure whether the runner was too small last time or not. Next time I might do back to the narrow runner since it took a lot of molten metal to fill that thing up.
The pattern rammed up nicely on the first attempt. It wasn't perfect but the pattern area itself was pretty good, the runner had some crumbling along its edges that I tried to clean out. Making the runner even bigger then the wooden runner pattern. I don't have any pictures itself of the rammed up pattern. My "apprentice" might he was doing a lot of pictures, snapchat and videos of what I was doing (hopefully none of those videos see the light of day).
With a good pattern or at least one I was happy with I fired up the furnace. It was a coolish day out and I had a hard time getting it to stay lit. Finally got sensible and put the hot plate under the oil tank and got the oil warm - amazing difference in performance on that. Actually had to cut back the amount of oil going in because it was burning too rich. Lesson learned even if its a comfortable cool day, get the hot plate out as the oil viscosity really affects the burner.
I filled the A12 crucible full of brass shavings that I had saved (as well as spent .22 casings and some miscellaneous brass/bronze fittings that were buried in that pail. Once that melted it left a fair amount of crap on top, guess the small chips oxidized more then big stuff did. After scrapping that off the top and then adding more big fittings and the like I got about 2/3 - 3/4 of the crucible full of molten metal. I let it heat up till it was nice and viscous.
I used the old lifter/pourer - now relegated to crucible lifter to get the crucible out of the furnace and then the new pouring shank to pour with. The only headache was the plinth got stuck to the bottom of the crucible again :-( but didn't seem to effect anything just a bit in the way is all.
When I poured the top half started to lift a bit causing some bronze to seep out the split, I stepped on it to get it back down and continued to pour out the entire contents of the crucible into the mold. A small amount started coming up the riser above the center of the hub - basically to the level of the bottom of the riser extender. But didn't go up into the extender. With the crucible empty and the pouring riser full but not a lot in the other riser, plus the lift of the two halves I was certain that this was yet another failure.
After waiting an impatient 10 min with "apprentice" and wife harassing me about whether it was a success or failure I dumped it out into a wheel barrow to prove it was a failure. Much to my surprise the riser on the hub had fed the pattern nicely and while it had shrunk down in the middle to almost next to nothing above the pattern, it had done its job and the pour was a *SUCCESS*.
The only negative at the end was the when I tried to lift the cope and drag to get it into the wheel barrow the sand in the bottom of the drag broke loose onto the ground. Next time I'll lift with the board it was sitting on.
After letting it cool for a good while - aka cleaned up all the pouring stuff, put away the lifters and pourer and all that paraphernalia. I came back to the casting and hit it with some water to cool it off and then cut off the riser above the hub and the in gate. Both were solid, though I bet the riser was empty a 1/4" or so above the hub.
I started machined it later yesterday evening. I should have done a few things differently but it came out ok. I still need to drill the holes into the face of the flywheel. There is a funny - smearing area on the face of the flywheel and a couple of tiny pinholes on the circumference. But overall it was a complete success.
In order to machine it, held the side without the extended hub in the 3-Jaw on the outside then I machined the face and hub to clean them up. This is where I made my mistake. I did not go to final dimensions anywhere, I just cleaned up this side. I should have taken everything to final dimension or at least within .020" so that when all was said and done it would be just skim cuts to finish off after cutting off the hub extension. Oh well, lesson learned. After roughing the first side I used the spigot or hub extension to turn the opposite side to final dimensions and turned the outside diameter to approximately final size. Then flipped around and tried to finish the first side using the inner hub to hold - it worked but it was a bit flimsy and did at least once pull it slightly out of running true. Next time I either completely finish the first side or use the outside diameter to hold when finishing the side where the extended hub was. This is the first time I've turned a casting like this so it was a learning process. I had the idea correct just not the execution steps in the right order.
Pictures to follow from my iPhone momentarily in a separate post.
