Here's something to make you drool!
I have to admit, I didn't expect that to work. But I had to try. Well, the first two tries failed miserably, but I had enough headroom to tune the parameters and try once more.
So I cranked up the vacuum to the maximum and casted with 710°C. That worked. An other try with a bit less vacuum and 700°C also worked.
That means, I still have some room to get a better surface finish. But as it is now, slight sandblasting will give me what I want.
Handwheel for my Deckel FP1 model.
This handwheel is the bigger one. It only differs in diameter, the spokes etc. have the same dimensions.
The brown spot on the left of the rim is a cast bore. ø1.5 mm, 1mm deep. Diameter of the wheel is 16 mm.
The spokes are ellipses with 2mm mayor and 1 mm minor diameter.
There is some flash on the inner of the rim. That resulted from the milling bit being "too big". I'll tune the core box by hand at that place.
Other view. The axle also is the ingate. Diameter 2.5 mm.
At the remains of the runner, you see that the molt is succed out again. I had a spot in the mold that wasn't completely closed.
Crank for the Deckel. 13 mm wide. The handle is 8 mm long and has a diameter of 2 mm at the narrowest spot.
Handle that goes into the handweel (the cast bore).
Right from the handle is the switch for the spindle motor. Gets sawn off, so that the platen is just 0.3 mm thick.
Core box and core sand mould, one half ...
... and the other one.
Was that worth waiting for?
Nick
