peterl95124
- Feb 22, 2020
- 524
- 344
Just out of curiosity I ran up a couple more small motors today. Both with the same 21w 12v bulb for load. One was 14v from an old drill(so probably high RPM.) It barely illuminated the bulb and was showing 4.5v the other was marked as 12V showing 10V brightly illuminating the bulb. Very similar physical sized.
A question for the more knowledgeable in the subject. - Brushless motors are rated in Kv which is how many RPM per volt. How might this be applied to using the motor as a generator? Say for example we had two motors that were similar in physical attributes but one was rated at 400Kv and one was rated at 100Kv. My guess is the 100Kv would be higher torque as it is lower speed for the same voltage. Would it be correct in assuming this is therefore the better option.
similar sized motors can have very different armatures, especially wire size and number of turns, which greatly affect output as a generator, more turns will equal higher output voltage (just like more turns in a transformer secondary equals more output voltage). you can sometimes count the number of turns, but you'll have a hard time measuring the magnet strength or the magnet to armature air gap, so you'll have a hard time doing the math. predicting the output voltage will be difficult, you're probably stuck with trial-and-error.
you could see what I mean by getting three standard sized RC-car motors from the same manufacturer with different numbers of armature turns, for example 8, 16, 32 or there abouts, and you'll see that you probably won't be able to spin the 8-turns motor fast enough to generate the same voltage as the 32-turns motor (if all the rest of the internals are the same then you'd have to spin it 4 times as fast).
