I am just a little concerned about your testing... The motor original rating will be a voltage and
power rating, - which also relates to the heat/temperature that the motor can withstand. (I.E. inside the windings).
Heat is generated by current, not voltage, so while it is good to note the voltage "open circuit" you need to do some tests with a suitable load (a filament bulb?) and record current as well as voltage.
And you must make sure it does NOT exceed the original motor voltage, as the winding insulation is "not new" and may well be worn or damaged and any excess could flash-over internally - creating a local source of heat that will destroy the motor.
Do not exceed the power rating (voltage x current), and after deducing the original current max continuous rating (Power rating divided by Voltage), make sure you
do not exceed the current rating either.
e.g. 90 W at 220V = 0.41A.
0.41A at 100 v = 41W. - so a 41W bulb at 100 V is 100/0.41 = 244 OHMS. I.E. a 0.6W bulb at 12 V, or a 200W bulb at 220V would have the same resistance so can be used to simulate the 100V running condition. Of course a 100W 220V bulb is about twice the resistance (484 Ohms), so about half the current so would be a good current limiter for test purposes. I guess these may be available wherever you shop? - IF you can still get filament bulbs! 2 in parallel should be a good full load at 100V, But NOT for a higher voltage.
Incidentally, 100V can kill if it gets across the heart, so please practice the best electrical safety procedures when wiring-up and running these things. I only takes 1 shock to stop the heart. - We want you to avoid that and finish this interesting post.
I hope I am not too far from the "electrical truth" as I am a humble "mechanical" man... Bits of moving metal are easier to comprehend in my brain than "invisible" electrons and Electromagnetic "fields" - and heat, volts, thermodynamics, women, and all the other mystical things in the universe, etc...
