Time to make some really tiny parts. But first, how to part them off without losing too much material. I don't want to make a part that is only .052" thick and then remove more than that parting it off. So...
I took a piece of broken bandsaw blade, .025" wide, and cut/ground it to fit in the parting tool holder. Made a tapered piece of aluminum to clamp the blade in place. It is a bit flexible, but only needs about 1/4" protruding.
To make the spring retainers I started with 1/4" rod and brought it to the correct diameter for about 1". Drilled it as required to the same depth.
Used a 3/16" end mill to produce the counterbore in it, .020" deep.
Then used my little parting off tool to produce the groove in the backside, .030" in from the end and about .125" dia. The parting tool worked great. I didn't slow the lathe down much from normal machining speed for this material/diameter.
Zero'd the dial and then moved it .022" to the left and parted it off. Before the parting was done I cleaned up the edges with a small file to minimize the hand work after.
Then just clean up the end that is still in the collet and repeat. The cut-off part needed a little cleaning up since even with very light cuts with a sharp cutter the inner hole does tend to close up a bit from the material rounding in from parting. But doesn't take much to clean up, other than trying not to drop it or file my fingers.
It is difficult, for me anyways, to get a decent picture of tiny parts like this.
Rick
Rick
