Liney RV-1 - A New Double Wide
Nicely done Stan. Looking forward to the finish line
Phil
Very nice Stan. Also very good machining pictures.
Barry
Final build log tomorrow but....
IT'S A RUNNER!
Now I have to take it apart, polish, paint, fettle.
[ame]http://www.youtube.com/watch?v=b4tYOLHrPJs&feature=youtube_gdata_player[/ame]
Stan, great looking engine. Great runner as well. Keep it up and we will need 3 tables at Cabin Fever :D
Stan,
Nice looking and running engine. Will be nice to see it at Cabin Fever 2014.
Phil
At this rate he will have a half a dozen new projects to show us.
Part 8
Grand Finale
The speed build is done. Now to finishing and final assembly.
The base and flywheel will be painted. I cleaned them both with lacquer thinner. The base plate was bead blasted to give the primer something to grab.
I’ve had good luck with this self-etching primer. A few light coats and it’s ready for paint.
Also been happy with this masking tape. The paint does not creep under the edge. Since I had already polished the flywheel rim, I masked that.
While the paint was drying, I sanded and polished the valve block.
The baseplate and flywheel have three coats of paint and one coat of clear lacquer.
Assembly is begun with the flywheel and bearing towers.
Heading other builder's advice about crank mis-alignment, I rested both crank pins on a pair of parallels and tightened the set screws.
The valve block was next in line.
The rotary valve was slipped through the valve block, then one piston and cylinder was attached with a set screw. The other cylinder/piston pair was slipped on.
That’s it. I’ve run it for about an hour and it’s down to around 10 pounds although the compressor gauge isn’t that accurate at low pressure so it could be less or more than 10 psi.
Thanks for watching.
Video will be posted in the Finished Projects section.
