Exactly the point, that the complexity is not built into it to "Confuse the Russians".
For just sharpening twist drills it is maybe not the easiest alternative. It was another time also. Today the variety of available tools is much greater, entry level tools are more affordable (I am guessing that).
And the variety of easy to use specialized machines grows constantly.
Other machining tasks can be handled by a CNC movement, allowing to use more simple tools instead of form tools.
Todays experiments with the 2nd hand japanese machine. (I do not own a Quorn)
bought some 6 mm drill blanks yesterday. Tried to convert the blank into a tool today.
Out came this (don*t laugh
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) Setting up these grinders without any clue
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
by trial and error. It is a challenge. Outcome looked very odd, I could invent some story that it has a purpose, but it is just what came out of the combination of angles and trying to cut a flute.
It drills very good in wood and plastic, because of the big space for chips. Drilling mild steel worked reasonable well. Very thin web and small chisel point.
I had another look at my spot drill and tried to copy its "look", this was the result. Looks almost like a real drill and it even drills holes into steel. 90° tip angle.
What I find confusing is that the cutter grinders seem to be all "one off" designs with a lot of differences, operation concepts and accessories. Very complex. I learned about the Deckel machines "S1" and "Martin Deckel S11"
Greetings Timo
