Figured I would update where I'm at. Was able to finish up the block machining except for bottom holes. i want to make a base out of welded steel to resemble economy hit and miss engines, plus 50$ just for the base in alum.
Here's a veiw of the undercut and bore. There's some chatter marks on my undercuts but should be ok. This was a hard part to turn in the lathe with the the off balance, I couldn't get anywhere near the speed needed.
The bore went okish with cutter issues but using carbide in my homemade bar was as good as I can for now. I have a 1.5 lap and flex hone on the way . The white marks you see are from my fingernail so that gives an idea of the roughness
The rear view and the cylinder ready my first ever shrink fit. I've read another build log and followed his example for a .003 interference fit. So we'll find out how good I did or not
Top view with water tank. I chose square to avoid the undercut . I will make a bolt on top later on.
