Thanks Brian, Jim, and Gus. I am glad you are enjoying the build. Today I finished the bores in the bearing supports and caps. After mounting the caps to the bearing supports I drilled the bores using a 1/2 inch drill.
Then mounted them to the base, clamped it on edge in the mill vise, and finished the bores using the boring head.
Here are all the finished pieces assembled. Next up will be the crankshaft. I am going to attempt a one piece crankshaft.
I used 316 stainless for my Kerzel cylinder, because I didn't want to look into the water reservoir and see rust. I have been told since that 316 stainless was a bad choice for cylinder material if you plan on using metal rings to seal the piston. I used a Viton o-ring, and have never had a problem.
