Thanks Brian, Jim, and Gus. I am glad you are enjoying the build. Today I finished the bores in the bearing supports and caps. After mounting the caps to the bearing supports I drilled the bores using a 1/2 inch drill.
Then mounted them to the base, clamped it on edge in the mill vise, and finished the bores using the boring head.
Here are all the finished pieces assembled. Next up will be the crankshaft. I am going to attempt a one piece crankshaft.
