Notice the 5 centerbores in the end. The hidden end has similar centerbores.
Its time to mount it in the lathe. I first placed a piece of bar in the chuck and turned a live center. I have a live center that fits in the spindle taper but I like the chuck idea cuz I think its more accurate, less likely to wobble.
I rough in the main first.
Next I turned the throw pins to final size. The tool looks like a parting tool and it is but its been ground to more resemble a turning tool. The corners have been broken. Having a chamfer in the corners strengthens the crank. I'll releave the rods to allow for the chamfer.
Steve, going to the meeting Wed?
"Curious to know how you were able to form the 5 centerbores on both ends of the crankshaft. How did you align it such to have the paired centerbores opposite of one another yet parallel along the axis?"
Thanks for the question. Answer is that within reason they don't need to be aligned cuz any misalignment gets turned out. To get them close though I first clamped the bar on the mill table and milled a flat on each end of the bar. I then stood the bar in the mill vise with the flat against the solid jaw, dialed in the center and center drilled the spots, flipped the bar end for end and did it again. Yeah, the bar was sticking up 6 inches.
Not sure how that would be ok. Wouldn't the crankpins be slightly off then? Wouldn't that then cause the pistons to be in the incorrect position in relation to each other? or is there a decent tolerance for engines?
Wow, that really does sound effective. Having that flat spot would prevent it from rotating out of position when flipping it end over end. Ingenious!
I've got to split the rings before heat treat. Clieving compression rings is easy but I'm bewildered about slitting the oil rings. Seems the oil rings don't clieve to neatly. Any suggestions?
