Hi Lloyd -ss !Minh Thanh, Is that table for the two materials rubbing/sliding against each other?
It's a material combination table for cylinder and piston but I think it is extendable for shaft and bearing,,,
Closing the inlet port with the plunger as in full size practice removes the inlet valve from the problem and defines the start of injection accurately. A ball inlet valve tends to trap air and the closing and hence the start of injection is not well defined.
Roger, thank you for sharing your testing documentation. Is the system gravity fed? If it is, would a low pressure booster pump timed with the high pressure pump possibly reduce what appears to be a cut-off at about 4mm^3 per injection? I am assuming that the higher output volume per rack position at the higher rpm is because the internal leakage in the pump becomes less of a factor?
Nice linear increase in pump output.
Good work. Thank you.
