gmac said:
Ron Colonna uses 0.010" pure silver sheet (not sterling silver) for his Offy engine which is a pressurized oiling system with dry sump. He also superglues the ears of the shells to the cap/rod halves.
Garry
Thanks Gary, I didnt know Ron used that too. I included allowances for the single tang overlap when I spec'd out the reamer, we will see how long it lasts.
Sidetrip to Hades!
When we last left off I was anticipating the arrival of an ebay purchase to throw together a cheap (and quick) heat treat oven. The results were a FAIL, but somewhat encouraging.
What you see here is the ebay $12 special surplus temp controller, an old toaster oven (~$15 at wallmart 8 years ago), a brand new 120v relay and socket ($13 mcmaster), hi temp fiberglass rope seal ($6 mcmaster) a K type thermocouple (gift), and a few scraps of wood and wire. The controller was an "H" variant, which means it simply turns off at the desired temp. Not what I had in mind, but it would work if babysat and continually reset. Despite the approximately 1300 degree heating elements, the max temp achieved was 755 F. So, for the price of a day and a half work, I failed. I now have some high temp insulation to help with the heat loss, and a single 750 watt cartrige heater, so the second iteration of this is coming shortly.
Of valves and cages
Earlier I mentioned I had never tried to make a caged valve system, and that hasnt changed. The forums have been pretty active with valve discussions lately, and I have weighed all the advice I have seen. I still dont have anything against the cage system, except my own inexperiance. While I have a lot of experiance with full size practice, I went that route for a test head. Cocentricity and accuracy in the setup will be challenging, so here is my take on it.
Start with a head! I always feel like a sculptor at this point, chop off a block of 1.5" square 6061 1.1" and true it up to 1" height. Then, get so darn excited you forget to take pictures of the 1 3/8 counterbore and 15 degree cut for the combustion chamber
Once off the lathe its back to the mill where I "lop the ears off" for another 15 degree cut.
Now life gets interesting. Back to the lathe with a 3/8 stick of W1. Drill a bore with a 19/32 drill. In my case I ruined the part with a dull cobalt 19/32 drill :'( Out to production tool and 8 dollars later we have a replacement cobalt drill that actually cuts. Follow up with a delicate touch of a 90 degree countersink. Then we turn a whole length down to .350. Carbide inserts and plenty of lube keeps the surface finish up to snuff. Trying to part a .200 length off for a valve seat just dulled my A1 fin tool.
Switching to my commercial (hard) parting tool I find the piece wont part off, the tube just deflects away from the cutter. Trying to make lemonade out of lemons, this appearant work hardening is not a bad quality to have for a valve seat, but required an old nearly abandoned practice of a dremel mounted with an abrasive cutoff wheel to part off. This was the
very first tool I made when I bought that lathe 13 years ago, and I havent used it since, but it sure saved my bacon this time.
Sorry, so excited I forget the pics of the seats by themselves.
Now that leaves me with all this stock sticking out, already turned to the same size as the seats. I turned a .1870 pilot on the end and proceeded to make a counterbore/reamer tool to ream the seat cavity in the head. Press fits are new to me as well, and a lot of creeping up on dimensions with abrasive cloth was indispensible. I also made an installer tool (also not pictured), similar except for a looser tolerance pilot, no cutting teeth, sized 19/32 for the inside dia of the seat, and made from cheap 10something cold rolled steel. I spent a hour reading machinery's handbook on making cutters, and found it (26th ed.) pretty lacking in the counterbore section. I did pick up a few interesting bits such as cutting the flutes .010 below center to give the sides some rake angle, (and a smidgeon smaller for the press fit), and to offset the teeth +- 1-2 degrees. Eventually I came up with this.
On to the drilling
Keeping everything concentric is the major challenge here, and I took it to heart. I realized early on my drill chuck seems ever so slightly eccentric, mounted only with a 33 jacobs taper to a 1/2' straight shank for holding in a collet. To avoid using the chuck I ran out at the last minute back to production tool and bought a quality 3/16 R8 collet for the guide hole reamer, then I could use the 3/8 collet for the seat hole reamer. This worked marvelous, with the exception of forgetting to relieve the cutting teeth on the seat reamer I made, hence the first guide is slightly higher then the flush surface I was shooting for. A bit of quick work with the dremel fixxed the tool and the second seat came out exactly as planned. The press fit for the seats came out perfect as well, just a few stiff taps with a hammer drove them all the way home, with some red loctite for good measure.
Now were all up to date again. You might be able to see in these pictures what I considered a problem with the origional Edwards radial plans, that when you bisect a cone off-center with a cylinder, the resultant surface is shaped just like a wave washer. Making the valves seal against that is one thing I saw omitted from the plans, which led me to cad model it, which in turn led me to this point.
Coming up next, we have plenty of chips still to make. Bronze (yep, I splurged and bought the good stuff) will be turned into valve guides, and you will experiance the absolute horror as I mix in a metric dimension into an otherwise all english unit design. We have counterboring, and drilling through aluminum to bisect the tool steel valve seats for the ports. It may be coming up on Christmas, but the next installment looks like a better fit for halloween. :-\
