Dancing in place
Got some devoted shop time in this week, got a few things done but in the end, it feel a bit like I got nowhere.
We had to stop trying to start the motor when one of the mounts broke. Here is a pic of where we left off, you can see the fatigue crack across the mount at the bottom two mount bolts.
So, mounts are rather boring.
I also wanted to install a crankcase vent. This should have been obvious, but when both pistons move towards TDC or BDC in unison there is a tremendous pumping action generated.
In boxxer motors you cant forget the vents. This necessitated a total teardown to drill and tap a 1/16npt hole.
This hole looks like it was firing. ;D
One of the things I thought would help overcome the compression would be a little more flywheel effect. I found an old kent moore transmission tool which was 1 3/4" diameter, not ideal, but it was the biggest thing I had that didnt already have the wrong size hole in it. I bored the hole tight for the crankshaft, but had no luck whatsoever trying to use the lathe shaping trick to put a keyway in this particular piece of mystery metal. I eventually milled the keyway with a 1/8 carbide endmill in a plunge cut. A quick moment with the belt sander made a brass half round half square key. I just hope it clears the oil pump cover or it may need a little extra work.
Realizing there was no good place for this large vent, which was the smallest available and under 2 bucks, I settled on a spot that hopefully will miss the intake manifolds.
Then came the big decision. I wasnt totally happy with the first camshaft I made. It was functional, and should start and run the motor, but I wanted to make a cam that actually hit the numbers. The bearing surfaces hit the numbers, but the block turned out a little oversied, so I also wanted to add a couple of thou back on the journals. Aside from that, the base circle was a little wavy and that made lash adjustment nearly impossible. Finally, not the least of the reasons, was that I wanted to use my new dividing head I picked up at NAMES.
I didnt have a good height guage either back when I made the first cam, so layout was a breeze this time around.
This cam was made with a slight radius to the lobes, instead of the flat ramp design like the first one. It was made by the milling method, using the calculator right off Ron Chernich's website. I had already made a proof test of a lobe this way several years ago. It works well if you can maintain your concentration and enter all the right data into his online calculator.
This is what happens when you enter the wrong data.
It seems if you have a .25 base circle on a piece of .375 your lift is only .062 not .125
All was not lost however, only a 2.25 inch piece of 41L40. I corrected the calculations, transferred it to a spreadsheet, added a bunch of nmenonic notations to put the bumps in the right places and practiced on the wasted cam. That lobe came out perfect, taught me the virtues of developing a routine, and I quickly went to work on another cam blank.
Armed with this newfound knowledge from the school of hard knocks, the remaining 210 step cuts and 24 turns +16 holes for each base circle went rather uneventfully. At the very end I had something that looked like this.
So I accomplished quite a bit, but never got around to the mount problem I set off to tackle in the first place. I have some nice shiny new pieces, but the engine is in different Mcmaster bags awaiting reassembly. Maybe sometime this week we will get around to that mount work.
