Yes Gus--Be shure and bolt that engine down to something solid.----if it starts up you will be chasing it around your apartment. That type of carburetor depends on having a hit and miss mechanism to control the revolutions of the engine. If you start the engine with just that carb in place, and no hit and miss mechanism, be aware that there is no throttle on it, and it may rev out of control. If you are going to build the hit and miss mechanism, you're fine. If you don't plan on building the hit and miss mechanism, you need a different more complex carburetor. I have a set of plans for the more complex throttled carb that I can send you.---Brian
