- May 27, 2010
- 2,999
- 1,171
Sorry . Gus accidently delete your message.
You are right about the inlet spring being too strong.Put any old spring for now.Will put in the same spring I used for Webster.
Been a productive day in terms of good work. Rocker Arm and support done and aligned. Rocker Arm profiled as per Brian's drawing.Push Rod sub-assembly done too with the dimple at Rocker Arm done spot on.
Will put in push bar retract spring same as yours.
The timing gears and cams will be next. All these take time and no rush. Will report half gear tooth if it ever happen.
See foto.
See foto.
![IMG_2288.jpg IMG_2288.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/20/20611-IMG-2288.jpg)
