stackerjack
- Sep 12, 2014
- 80
- 12
I've built a grinding spindle using bronze bushes. I haven't used it yet. Do you think there will be any problems?
Jack
Jack
If you've accounted for the heat generated at the RPM you intend to use it at, it should be fine. Is oil pressure fed?I've built a grinding spindle using bronze bushes. I haven't used it yet. Do you think there will be any problems?
Jack
No, I'm afraid it isn't. It's just got an oil reservoir mounted above each bearing housing, similar to a Myford Lathe. I cut a spiral in the shaft to persuade the oil where to go.If you've accounted for the heat generated at the RPM you intend to use it at, it should be fine. Is oil pressure fed?
Worked for an aerospace company for 20 years. Built aircraft generators usually 2 pole at 400 Hz 24,000 rpm and rocket driven turbines that spin at a much higher speed. Rule for bearing is always to preload them. This insures the balls are always rolling. Do not want what happens with the tires of a plane touch the ground happening to the balls. Obviously the higher the speed the better the bearings needed and also the lubricant. Also preloading helps to insure the axis of the bore and the shaft are the same.Hi Guys,
I used dual bearings in my grinding spindle at both ends.
The shaft is secured in the pair of bearings at the wheel end and can slide through them at the drive end. Total cartridge length about seven inches. I actually did away with using an "O" ring to provide preload and replaced it with a shim, relying on the threaded end cap to prevent the bearing pack from floating in the housing.
You say that when bearings are pre-loaded, the balls will always be rolling. I cannot see how the balls will roll on two surfaces of different diameters, being the inner and outer races.
Sorry, but I disagree with this.Its is the same situation as having three gears of different diameters running together.
Thank you for your very explicit response, I'm afraid I'm not conversant with the formulae. So, what you are saying is that: the balls just deform to allow them to "skid" along the tracks. You are correct in stating that the contact area is extremely small, this is what causes very high pressures between the balls and the tracks, even when the load is not very high, which is presumably the cause for the deformation.All bearing are angular contact when preloaded. as you can see that the balls contact at a circular line of contact on the OD and ID race that are different diameters. The contact is a very small area for each ball. due to the metal under load deforming elastically like for example press a rubber blall or even a basket ball against a glass you well see the contact is as shown.
Eh? No, no, no - the balls roll on both races, in spite of the problem you seem to be having with the idea. I think BaronJ may have been refering to epicyclic gears, in which case the comparison is most helpful. I am expecting soon to hear the tinkle of a penny dropping.So, what you are saying is that: the balls just deform to allow them to "skid" along the tracks.
I disagree with a great many things, but this does not necessarily make me right.
For simplicity of illustration, ignore deformation/non-point contact patches. These actually do complicate things somewhat.
Take two horizontal, parallel infinite planes, and place a ball between them in contact with both. Do you agree that one plane can translate left/right while the ball rolls without sliding, in contact with both? If you do, then you disagree with your disagreement.
Consider that the contact between the ball and the upper plane is a point.
Because the contact between the ball and the upper plane is a point, is there any conceivable way that the ball knows that the upper plane is a plane, rather than a cylinder?
Since the answer is no, convert the upper plane to a cylinder. Balance it on the ball and roll the whole thing along left or right - does anything need to slide?
The exercise is left to the reader to extend the illustration to an outer cylinder and an inner cylinder, instead of a plane and a cylinder.
the balls are like your car tires. they roll instead of slide. The tires roll on flat, concave, and convex roads and stay or track in a worn cupped out track. Balls act the same way. The lubricant is like having a wet road. So long as the acceleration of the ball is low it rolls instead of slides. So a ball that in not in contact with the two races like a non preloaded bearing during some portion of the circle then it slows up. When it makes contact and loaded it must accelerate in a very short time period, skids. The formulas are not important except for those that design bearing. In reality the life of a bearing is determined by testing. The testing information is provided on each bearing. This use is within the range of the data. Have question give the company a call. Purchase the bearing from suppliers that provide access to the manufacture.Thank you for your very explicit response, I'm afraid I'm not conversant with the formulae. So, what you are saying is that: the balls just deform to allow them to "skid" along the tracks. You are correct in stating that the contact area is extremely small, this is what causes very high pressures between the balls and the tracks, even when the load is not very high, which is presumably the cause for the deformation.
Further to my asking for your ideas please take this as a large thank you to everyone.Hullo, I looking for ideas really. I retired from precision engineering, college workshop technician and 30 years in a shipyard and now have a small Colchester student and similar size vertical mill. I have been making the Quorn t/c grinding machine, which has been a challenge but enjoyable.Being me I am looking to remake the grinding spindle with a different design, perhaps angular contact bearings , just because I can, nothing wrong with the original design by the way. I'd welcome ideas on this please.
