Below a 15kW circular saw spindle I designed and built for sawing off aluminium casting sprues using a 150kg payload robot.
Note the close proximity of the working end pair of angular contacts (I have switched off a lot of the detail layers as it gets far too busy) - the fit up of the assembly is determined by the spacer between the bearings. If it was a grinding spindle I'd have gone for spring loading.
and just the working end
But this outlines the general principal for any machine spindle - a pair of bearings close together at the working end and an outrigger support some distance back for stability.
If you were to simply place a bearing at either end, expansion and contraction are going to play havoc with the clearance and hence inconsistent play in the spindle.
P.S. The seals are to keep coolant (souluable oil) out rather than lubricant in.
Regards, Ken
Regards, Ken
