R
RobWilson
Guest
??? Themit / Thermite use's iron (III) oxide,,,,,,,, ( Fe2O3 + 2Al → 2Fe + Al2O3 + heat) So it should use the suffix ate for more/lots of oxygen ,,,,,,,,, Thermate ;D
Rob
Rob
Rof} Rof} Rof} Rof} Rof} 'dynamate' I think they sell that on QVC :big: :big: :big: :big:tel said:;D Yeah, that makes sense. After all, we use ammonium nitrate to provide oxygen for a certain (ahem) 'procedure'. And potassium nitrate for another. Some'ow 'dynamate' doesn't sound quite right tho'.
Woz said:I've been reading this thread with interest. Do the warnings about grinding on the side also apply to those drill sharpening jigs that work that way?
I grind aluminum on a 2x42 belt sander. If I had a need to grind on a flat surface the belt sander is my choice.A bit off topic but still about grinders...
Has anyone heard of/experienced a chemical reaction/fire/minor explosion when grinding both steel and aluminium on the same grinding wheel?
(Not as in grinding both materials at the same time, but one after the other.)
Good choice... until a sharp edge catches the join in the belt, been there, done that!I grind aluminum on a 2x42 belt sander. If I had a need to grind on a flat surface the belt sander is my choice.
LOL, I am an instructor, and I tell my students when they break a tool that that is what learning is all about. Who hasn't broken a tool? One student did exactly this, ripped the belt! Unluckily, we didn't have a replacement belt, but the ript belt was still usable by about half of it.Good choice... until a sharp edge catches the join in the belt, been there, done that!
