R
RobWilson
Guest
??? Themit / Thermite use's iron (III) oxide,,,,,,,, ( Fe2O3 + 2Al → 2Fe + Al2O3 + heat) So it should use the suffix ate for more/lots of oxygen ,,,,,,,,, Thermate ;D
Rob
Rob
Rof} Rof} Rof} Rof} Rof} 'dynamate' I think they sell that on QVC :big: :big: :big: :big:tel said:;D Yeah, that makes sense. After all, we use ammonium nitrate to provide oxygen for a certain (ahem) 'procedure'. And potassium nitrate for another. Some'ow 'dynamate' doesn't sound quite right tho'.
Woz said:I've been reading this thread with interest. Do the warnings about grinding on the side also apply to those drill sharpening jigs that work that way?
I grind aluminum on a 2x42 belt sander. If I had a need to grind on a flat surface the belt sander is my choice.A bit off topic but still about grinders...
Has anyone heard of/experienced a chemical reaction/fire/minor explosion when grinding both steel and aluminium on the same grinding wheel?
(Not as in grinding both materials at the same time, but one after the other.)
