This thread originated more than 9 years ago, so quite a few folks are late to this particular party!Late to the party ...
After I got home yesterday I began searching for more information on piston valve timing . I can now get the power piston exact location. TDC or BDC . So moving over I can measure the piston port valve position with the “ very near calipers” in relation to the i power piston , carting this a step further I just got the new tapered 1/4” 40 TPI ME die. So I can thread the 1/4” pipe with taper threads then chase them with the straight die. I know this is not perfect but it gives me the ability to make a 40 TPI screw that will screw into the exhaust port right over the piston valve . Effectively giving me exact position in relation to the power piston . So after viewing a number of videos , some consider these small steamers not worth the time to fuss with the port timing. The power piston does have clearance at both ends of its stroke for a cushion effect . This seems to eliminate the “knock”?that some larger engines seem to have . I’m assuming it’s a looseness in bearings. M little steamer has pretty snug bearings especially with oil in them .This thread originated more than 9 years ago, so quite a few folks are late to this particular party!
thats a clever method of connecting shafts I’ll have to remember that one.After I got home yesterday I began searching for more information on piston valve timing . I can now get the power piston exact location. TDC or BDC . So moving over I can measure the piston port valve position with the “ very near calipers” in relation to the i power piston , carting this a step further I just got the new tapered 1/4” 40 TPI ME die. So I can thread the 1/4” pipe with taper threads then chase them with the straight die. I know this is not perfect but it gives me the ability to make a 40 TPI screw that will screw into the exhaust port right over the piston valve . Effectively giving me exact position in relation to the power piston . So after viewing a number of videos , some consider these small steamers not worth the time to fuss with the port timing. The power piston does have clearance at both ends of its stroke for a cushion effect . This seems to eliminate the “knock”?that some larger engines seem to have . I’m assuming it’s a looseness in bearings. M little steamer has pretty snug bearings especially with oil in them .
It’s said the piston valve is better than the slide valve as steam does not push directly on it. One video noted the “wet steam” or “ vapor steam” that may have some oils in it. So that’s good . I’ll have some oiling anyway . I won’t get into real steam for a while until my boiler is done . At that point I’ll see what needs to be done as far as oiling . I do have an oiler available. As well as air compressor oiling .
With this I’m rethinking the timing issues.
Any comments would be appreciated .
I hope I’m not over thinking this . One of the race car competitors I ran into at the car show came ver and we re acquainted.
He said of all the racers I was type one that was toughest to beat. Quite a compliment. I bought us lunch.
Well another interruption . Another surprise doc visit . I should be thankful I guess the health people really take care of their people I changed the bandage on my hand to a skin colored one. Hope she doesn’t notice it. I tried to drill a hole in my finger. Fast reactions only allowed a small flap of skin to be peeled out .
Byron
Byron
i have some collars that I use as a doubler against the clamp collar so it will be really hard for the “ working collar to move I didn’t want to give up the shaft space but better that than have something move . I finally got the flywheel bores cleaned out by rolling a piece of fine Emory paper around a drill bit and using it like a hone I think the thread hole was bent over as that was the tight spot I polished the shaft but I can’t see any reduction in size. Just nice and smoothI’ll be watching for any movement . Fortunately I think I’ll now have a quick easy way to check on the eccentric position I’m not sure just how the main flywheel mounting is going to shake out I could use a shaft extension as ll have a outside shaft support with bearing in it once I get everything up and running I’ll be better able to see what I need.
Byron
M sitting here trying to get tiny things lined up and my kitty jumped on the table. Then she grabbed a small bag that had a shaft coupler in it that just arrived . She doe not play with anything hard let alone my stuff . But sh knocked iron the floor the grabbed the bag and took off. Cats are great at causing trouble then hightailing it out ofvthe area like nothing happened well it’s gone somewhere. Most likely under the bed. I’ll take a walk. Yup there it is an arms length under the bed. She is now curled up in her kitty carrier like nothing happened . At least I found t she could have smacked it under the fridgeAfter I got home yesterday I began searching for more information on piston valve timing . I can now get the power piston exact location. TDC or BDC . So moving over I can measure the piston port valve position with the “ very near calipers” in relation to the i power piston , carting this a step further I just got the new tapered 1/4” 40 TPI ME die. So I can thread the 1/4” pipe with taper threads then chase them with the straight die. I know this is not perfect but it gives me the ability to make a 40 TPI screw that will screw into the exhaust port right over the piston valve . Effectively giving me exact position in relation to the power piston . So after viewing a number of videos , some consider these small steamers not worth the time to fuss with the port timing. The power piston does have clearance at both ends of its stroke for a cushion effect . This seems to eliminate the “knock”?that some larger engines seem to have . I’m assuming it’s a looseness in bearings. M little steamer has pretty snug bearings especially with oil in them .
Byron
Re fixing a flywheel. I use the Westbury method which just works. I'm sure it must have been described in the Forum at some time. I first came across this method in the Model Engineering Mag years ago as described by Westbury. I don't know if the method is original or falls into the category of "obvious". Attached is my use of the method along with the extractor.
Mike
It is a great way too.
I’ve got a pile of shaft collars and couplers now I just got a jaw coupling for the larger joint flywheel it’s got a slightly larger hub but I have a coupling that will work it should be eas to remove the plastic spider in these small couplings make them hard to separate I could make a simple puller separated at some point but I have enough to do now. Also got rod stock for new piston connecting rods . I’ll add abou 1-2 threads on each end so there is more room for the jam nuts .
Yet another delay.
I went to drill a hole today with my cheap drill press. It’s actually be ok for a long time . I did a search to see if someone else had the same issue but nothing popped u
This is a female church mount with Morse #2 taper I cleaned it with acetone and carefully dried it then used bluing it looks ok it actually runs true for an old bench drill press . I reinstalled it and tapped it in . I was drilling tap drill for m 3 and it fell out broke the drill bit I didn’t give any warning . I’ve go this wicking blue lock tite, do you think this might work there is a very small hole in the bottom of the spindle but there realy is no way to put any cross hole it doesn’t have the tang feature.
Maybe I should just scrap the thing
Byron
Byron
Byron
Finally getting out to the shoo today. I hope I can finish all the little tweaks I want to make . I’ve got couplers and shaft collar that just need minor machine work mostly lathe work. I’m going to have to cut reliefs for cap screws in the larger shaft collars and couplers but I think I make a simple round holding fixture or just use a small end mill .Re fixing a flywheel. I use the Westbury method which just works. I'm sure it must have been described in the Forum at some time. I first came across this method in the Model Engineering Mag years ago as described by Westbury. I don't know if the method is original or falls into the category of "obvious". Attached is my use of the method along with the extractor.
Mike
This taper lock bushing really works well. My version is shown in the drawing attached to my March 31 post, but the taper is not specified. I used 3.5 degrees (7 degrees included angle) that I matched up by boring the flywheel taper and turning the bushing taper without moving the compound setup. You can see the extractor nut on the big end of the taper bushing.Morse tapper is about for locking on crack shaft. Brown and Sharp is a good tapper too but most do not have that reamer.
Boat prop use #2 Morse too.
I like see a reaFinally getting out to the shoo today. I hope I can finish all the little tweaks I want to make . I’ve got couplers and shaft collar that just need minor machine work mostly lathe work. I’m going to have to cut reliefs for cap screws in the larger shaft collars and couplers but I think I make a simple round holding fixture or just use a small end mill .
I managed to get the chuck off the Mickey Mouse drill press I YHINK I’ll try and reinstall it with the blue locctite an put a weight on the handle to put pressure on it while the loc tite sets up
Byron
I never received the dining room table , Shag carpet or Large cat. But faxs missing screw , the wrong size sometimes a photo of some one else bolts (wrong color). I can see some losing 0-80 or 2-56. My shipping was 1/2" and larger bolts bolts in 5 gal buckets.Byron,
RE: your kitty saga.
About 25 years ago I was manufacturing fully machined ready to assemble steam engine kits that had about 4 dozen 0-80 and 2-56 screws. One day I received a brief note from a customer that told it all in four short lines.
"Dining room table"
"Shag carpet"
"Large cat."
"Please send complete set of screws"
Gail
no missing screws just tiny hard to hold screws we drilled and tapped holes bored counter bores drilled plastic spiders and made new parts out of other sizes today had 32 pound Main Coon cat for bed warmer last night 10 pound tabby watched so nothing funny went on. Black and white patches the cat ruler guarded all of us.I like see a rea
How do you lose that. I try everything including taking photos.
It was alway my error. I just add to price .
Metal building companies had same problem too they shipped by 4,000 pound pellet of bolts.
It is problem for any supplying screws and bolts.
We got a lot done today so I can now finish assembly not everything the way I wanted but some parts did not machine well or could not be held securely . I think I have what I need to get back in business. We threaded some brass stock with the 1/4” 40 TPI ME tap and die and made better holders for the small round dies also drilled ad tapped a bunch of brass nuts so I have jam nuts then made half a dozen 1/4 40 TPI brass plugs. I have been unable to purchase these so I cut them from hex stock snd threaded them fit perfectly. Have temporary mounting plate for the throttle valve. I’ll make a better one later. We didn’t have any suitable stock . I ordered a piece of stock for shaft extension in case I need it . I’m going to make plans for a step up gear box timing belt driven to drive the generator I got from PM research. So it was a good day. I repaired the busted parting tool. It only has taper on one side so it must be a cheap piece . I put an equalizing shim in the holder and honed the cutting edges it works now . We made a couple spacers to hold the small dies in the holder better much easier to use now.
Byron
im right in the middle of sorting the reworked parts out. I hope we got every thing .no missing screws just tiny hard to hold screws we drilled and tapped holes bored counter bores drilled plastic spiders and made new parts out of other sizes today had 32 pound Main Coon cat for bed warmer last night 10 pound tabby watched so nothing funny went on. Black and white patches the cat ruler guarded all of us.
Byron
I made an interesting discovery last night . I discovered that certain shaft collars fit inside the rings on the lovejoy couplers. All I need to do is drill and tap locking screws and I’ll have a short coupling that grips the eccentric as well as the crankshaft . Saves a lot of tricky work . Plus gives the adjustment I wanted . It’s not as easy as wanted but other than testing it should work fine and be secure.im right in the middle of sorting the reworked parts out. I hope we got every thing .
The first thing I did at the shop was drop a small old ham coupling urathane spider on the floor . These are pink so very visible you can’t believe how far it rolled. It was like a ball bearing on an aircraft carrier deck one of the guys stepped on it is how we found it .
Byron
