Aluminum is fine for pistons if you are only running the engine on air. However, aluminum expands at a much higher rate than steel or cast iron when heated, so if you plan on using the engine with steam, there is a risk of the piston "growing" from thermal expansion and sizing in the bore.-----BrianWhy is aluminium a bad choice for pistons? I always thought it was OK to use![]()
