I made the small link for the rocker shaft (9/16" long) the first try was a failure, I tried making it with too small of a piece of brass. The second try I used a larger piece of brass with success.
To cut the tapered profile on the link, I used the drill bit to hold the piece down on the vice and set the test indicator over it to 0.
Then I moved the test indicator over the smaller hole (using the drill bit to center the indicator) and raised it .015, There should be .030 between the two ends.
Her is the final results, ready to be silver soldered to the shaft.
