- Jul 1, 2012
- 475
- 412
CHUCK
Special vise is excellent idea i have to do one for my needs too.
Juraj
Juraj
Is the side milling fixture a vise jaw with a clamp on top? I might have mounted the rods through the holes with tight-fitting bolts, but I love your solution.
Moving right along, I screwed up my courage and tackled the cam this evening. I mounted the fixture in my milling vise and used a 1/4" carbide cutter (with some broken teeth it turns out). I made 3 passes taking .020" per pass to create the flat on one side of the first cam lobe.
Then, leaving the tool height where it was, I repeatedly turned the worm wheel crank one turn and made a pass with the end mill. I repeated this 25 times around the blank until I had the lobe point formed.
Then I turned the worm crank until the cam as position back to the start of the first lobe.
Then I cranked the blank 120 degrees and moved to the next lobe where I repeated the steps for the first lobe.
After I finished the third cam lobe, I removed the cam from the fixture and dressed it up with a needle file followed by a touch up with 400 grid emery cloth. And here's the result.
I'm definitely in the home stretch now. My scale model nuts and hex rod arrived from American Model Engineering Supply today. So tomorrow I expect I'll be back doing some drilling and tapping.
Chuck
genius! Great idea!
Another brief update for today. I started on the rocker arms. I'm making them a little more complicated that originally intended. I think the results will be worth it.
I started with a piece of 3/16" thick cold rolled steel. I cut the width down to .8". The length is much longer than needed, but it's more about having a piece that's big enough to hold in the vise and other fixturing setups.
I've clamped the piece in my small horizontal vice which in turn is clamped in my milling vice so I can use a 3/32" clitting saw to put a groove in the sides.
Here I've turned the piece around to mill a slot in the other side. I've also put a piece of 3/32" drill rod in the finished slot so it won't be crushed shut by the holding vise.
And the piece with the slots finished. I made them a little deeper than I needed to, a case of the journey going so well, I lost sight of the destination! :
I've changed setups here and milling the waist that will be on each side of the rocker arms.
Here's the piece with the waist and slots finished. Next I'll need to part off the individual rocker arms and drill the cross holes.
Chuck
Very nice cam fixture Chuck! Is that a "standard" or you have to make one for every cam? I am definitely going to make something like this in the future. How are you clocking the cam? Counting revs on the handle and knowing the gear pitch? That is quite fascinating.
