Brian- A couple of suggestions for your next woodworking project, and other builders making wood bases for model engines.
Don't use pine. It doesn't stain well, and the grain is too large for a small project to look good. Use a tighter grained wood. Go to a hardwood dealer, and if possible, buy quarter-sawn wood, so it is straight and fine-grained. For a small project, the extra cost of a good hardwood isn't much. Resist the urge to stain it a dark color, or for that matter, any color at all. Use a wood like quarter-sawn cherry, and just finish it with a clear finish. It will darken by itself over time. Use glue very sparingly, and figure out a way to clamp so that you have access to the joint, so that you can immediately wipe away any squeeze-out with a damp rag. rotate the rag as you wipe, so that you are lifting the glue off of the wood. Some people finish the surfaces before glue-up, so that the glue wipes off easier. Do all of your sanding with a sanding block, so that you don't round over corners and edges. Don't use a high gloss finish, as it shows off minor imperfections in the smoothness of the finish. Sand lightly with 220 or higher grit between coats of finish. After putting on the last coat, I use a hard felt block and fine rottenstone with parafin oil to smooth the last coat, take out any little bubbles or other imperfections, and give it a satin finish.
Not meaning to criticise your work. This has just been on my mind for some time, based on lots of wood bases I have seen on this and other model sites, and I've been looking for an opportunity to make these suggestions in general.
