There's nothing especially original about this proposal-this is what aeromodellers and boat modellers have been using to start their glowplug engines for about the past 50 years...certainly since the 1970s-when electric starters became more common...in the form of the near ubiquitous 'power panel'....which runs off a 12V motorcycle or gel cell rechargeable (or latterly-a 3S Lipo, for those who have them)-providing 12V to the electric starter, 12V or 6V to the electric fuel pump (either integral to the panel, or plugged in as a separate accessory) and a purely nominal '1.5V' to the plug....in fact the plug supply is usually a PWM controlled pulsed 12V supply, since it is current that heats the plug element. Virtually all current panels use this system....and in some you can hear the pulse rate as an audible 'singing' of the panel when in operation. Most employ a manual pot to adjust the pulse rate-coupled with an ammeter, to adjust the average current to that needed by any particular plug to give a good glow...which could be anywhere from 1-1/2 (some of the cheaper beginner 049 engines) up to about 4 (heavy duty or racing plug) amps...there are a few that employ a sensing circuit that automatically adjusts the current to the load-but these tend to be a bit pricier.
As jack620 has posted above-the technology to do this reliably and effectively has been around since the mid 70s-using arduino is a case of 'gilding the lily'...and the early models didn't even use mosfets-just the available power transistors of the day...frequently the old reliable 2N3055.
With the increasing dominance of Lipo batteries in the modelling scene, there are a few newer options that involve voltage regulators rather than a switchmode approach-but these are intended to be used with a single suitable 1S Lipo, dropping the nominal 3.7V (4.2V at full charge!) to a safer 1.5-2V for glowplug lighting....these don't seem to have made big inroads into the glowplug starting market yet....but give them time...
ChrisM
