No more silly stuff, I'm actually building an engine here. It will have:
Two double acting cylinders that lie parallel to the output shaft.
There will be no conventional crankshaft or packing gland.
Both pistons will transfer their effort to the output shaft through a single shared actuator arm.
There will be two bearing like devices that prevent movement from side to side.
It will have at least 36 visible socket head cap screws.
There will be at least 2, maybe 4, parts made from common plumbing parts not including the two obvious brass pipes.
If it makes a "Pucketaa...Pucketta...Pucketta" sound I will not be surprised.
If it seems that there are parallels to earlier work undertaken by Chrysler and Rockwell, I can't help it.
I'm not going to do this like a regular "work in progress" thread because, as you can see, it is well underway. I will get a little more detailed from here on out because the build is approaching a point where it is greatly different from previous axial engines that I have shown.
All previous axial engines that I have built are single acting, meaning that force is applied to only one side (end) of the piston, pushing it in one direction with the return force provided by the piston rod. A double acting engine applies force to both ends of the alternately. This is one of the major differences between Internal Combustion engines and steam engines. Most, but not all, successful Internal combustion engines are single acting, while most, but not all, successful steam engines are double acting.
The single acting piston is much more simple. The piston is connected to the Con Rod, which is directly connected to the crank and the only seal of consequence is the piston ring.
The double acting piston connects to the piston rod, which connects to the Con Rod, which connects to the crank. It has piston rings and also a packing gland seal at the rod end of the cylinder. Because of the joint at the piston rod/Con Rod junction, there is also a cross head guide.
In my design the double acting cylinder has a plain head at either end, with no packing gland. There is also no crosshead guide mechanism.
Its getting late, and my eyes are getting droopy but I wanted to post the following pictures of the cylinder and piston.
Jerry
