- Jan 4, 2011
- 1,417
- 384
Just a little update. I finally got around to removing the welder from the saw and getting inside of the case. It took a little while to figure out that there is a 120v relay and it is actually fed from a separate 120v feed, not through the transformer. Strange but that is how it was done. It does weld after a fashion but not well. It appears that the welding is too slow and it ends up leaving a large gob where it welds and it is not a good weld. I tried a few different settings to see if I could improve the weld but so far I have not been successful. I will continue to play around with it when I get some play around time. At this point it is not a high priority so I will put it in the when I get "a round tuit" category for now.
