The crankshaft came out beautifully. Well, almost.
The rough-turning of the shaft from the sawn plate took a couple of hours, but with auto-fed twenty-thou cuts and a carbide toolbit it was pretty painless. Then, the last few thou with a HSS bit, down to the last couple of tenths, and the final finish (a la Brian) with emery cloth and a flat steel rule. Gorgeous, everything just the way it should be.
Threading the business end, where one day a 22x8 propeller will be proudly mounted...the first fifteen thou of thread depth on the lathe, finishing with a die...couldn't have gone better.
Then the final milling-to-spec of the rectangular end rotor, and the machining of the counterweight...all of this went as though blessed from on high. The counterweight nestled so nicely onto the rotor you'd have thought they were made for each other (which, of course....).
http://s1291.photobucket.com/user/mtitterton/media/Mic-ingfinish-milledrotor_zps1fc2cf32.jpg.html
Then, just one last thing before setting up to machine the crankpin bore in the rotor...drill and tap the holes to secure the counterweight.
Two beautiful tapping-sized holes, a half-inch deep to allow plenty of room for 3/8" of thread...
Then....
H O W L ! ! ! ! !
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
H O W L ! ! ! !
H O W L ! ! ! !
...the 6-32 tap snaps off like a carrot, at its full depth, and just refuses all encouragement to vacate the hole. An attempt to repeat the operation on he other end of the rotor crashes and burns (after two holes ARE successfully drilled and tapped) when it is discovered that the diameter of the hole for the crankpin is greater than the distance between the first pair of holes...and the remains of the tap. No drilling to be done there.
Oh, woe.
Well, at least I can salvage the counterweight. And maybe, in the fullness of time, I'll find something to do with my beautiful-but-useless crankshaft. Paperweight? Fancy tack-hammer?
So, I've ordered more steel (2" round this time, just to compare the two approaches) and another box of Kleenex. While I'm waiting for them to arrive I'm making some link rods. From nice, friendly aluminium.
Meanwhile, if anyone knows any magic spells I might use to make that broken tap vanish from that hole (Tappus Begonnus!!) I'm ready to boil up a newt or two. Just give me the recipe.
:wall:
