Duplex Vacuum, (Heinrici type stirling)
Fantastic Dean...this thing is going to be running in no time!! It's funny how digital cameras are so good these days that every minute imperfection tends to show up as you referred to regarding the piston. Drives me crazy at times. I will be out of town for the rest of the week and weekend but am taking the laptop...wouldn't want to miss a thing!!
Bill
That's looking great Dean :bow:
;D When I saw the photo where you were holding the part in your hand, my first thought was "A piston for a rocking engine - but its too thick..." - Isn't it about the same time of the year now that rockeritus broke out last year? :big:
Kind regards, Arnold
Mike, Zee, Arnold, Bill, Kel, Kevin, thanks much!
kcmillin said:
You have a nice pile of parts there Dean.
Kel
Kel, time will tell if they're engine parts, or scrap box parts! ; ) Hope for the best.
ksouers said:
How much clearance is there between the displacer piston and cylinder?
Kevin, the can is .715", hot end cylinder is .750".
Thanks again, all.
Dean
Hello folks. Little progress report here.
Two small parts done today. Actually, started one of them yesterday, but was slow going.
This little brass bit will be a toggle link that goes between the displacer rod that comes up through
the center of the piston, and the arm that moves it up and down.
Just a couple of holes, then milled it out and file a while to round off the corners.
And it goes like so.
This part will be another crank throw that goes on one end of the crankshaft and moves the works
that raises and lowers the displacer.
This dumb thing gave me the business. I picked it from one of my boxes of scraps-&-mishaps, (of
which I have a few). I don't know what kind of steel it is. Some kind of tuffolium, I guess, because it
work hardened when I gave it a serious look, and had me going to the grinder to resharpen bits a
number of times.
I should have just tossed it and used something else. It was only about 2" long, and it wouldn't have
been missed. I'm a double compound knucklehead though, and just kept rubbing it with the tool until I
got it to size.
Here it is to its basic functional shape, though it needs trimming.
A few cuts on the mill got it near its finished shape. Still needs much file work, but I was tired of it
by the time I got this done. I'll do the file work later.
It goes here, on the end of the crank. The flywheel for this side will fit over the inboard end of it.
Don't look too close. The camera is merciless!
Another assembly shot. Lots of fitting to do still, and quite a few parts to go. Haven't even thought
about the firebox yet, but know it's going to take numerous hours. It's all fun 'n games!
Thanks folks, for checking it out. Have a good weekend!
Dean
Dean,
Looking good.
Just when I start feeling cocky about what I did, I look at projects like yours and wonder if I'll ever be to a level that your at.
SAM
What, Sam? You're doing good.
I didn't build something like this on my first try, you know. We all learn in our own time. No hurry.
Dean
Dean, the camera is indeed an honest broker. Heh. Your rough parts look better than most of my finished stuff.
One question though. When you file on the little brass connector link do you file perpendicular to the narrow edge or along it? (Or both??)
Both ways, Mike. 90° to the edge to bring it down to size, then file going the same direction as the edge to clean it up and finish.
Depends on the material and size of the piece, too. If it's a thin piece, and not easy to clamp or pinch between pieces of wood, and the thin edge is not well supported, you pretty much have to file along with the edge to prevent it from rattling or chattering. Draw filing comes in handy in a situation like that.
Dean
That is some very interesting linkage for the displacer piston. In your photo, are the crank throws 180 deg apart? I am trying to visualize it rotating in my head. Does the linkage cause it to be 90 deg off. ? I ask because other stirlings are 90deg off.
Kel
Oh, I don't have it set, Kel. The parts are just fit together for an assembly shot, and to check for any binding in the running gear.
I think it's supposed to run at 110° out, so yes, it's close to 90°. I'll have to check the
prints to verify that.
Sorry for the confusion!
Dean
Dean,
Re: the assembly photo. Wow! Love the look of the linkage and brackets.
Dennis
Thanks For clarifying the timing Dean.
Kel
Thanks Dean. I was wondering just how you were doing that considering the thickness.
Cool stuff. Standing by for more pics and narrative.
Gosh darn, Dean, this thing is turning into a work of art! Nice work.
Chuck
Chuck & Doc; You guys are really nice. Thanks!
Appreciate you checking in!
Dean
Dean
I've been following along. I keep saying "wow" to myself, and not posting it 'cause it seems redundant... but too bad, Buddy:
Wow. Damn fine work :bow: :bow:
Looking forward to more, even if it strains the old vocabulary.
Cheers, Joe
Hey Dean,
Unfortunately I didn't get to check much over the weekend but am trying to catch up today. The progress is truly inspiring I must say. Something about the displacer and power pistons working on the same axis that adds a whole new level of fascination to this engine!!
Anxioiusly awaiting more
Bill
Joe, thanks! Redundancy is welcome. And, I do the same on your thread all the time, buddy. After
all, with a build like yours, how many different ways can a guy say "wow"?..:)
Bill, I appreciate you taking the time! One of the things that got me interested in this one
was the two-pistons-in-the-same-bore situation. That, and I've decided I really like Howell's stuff.
I'm likin' that Lindsey stuff, too.
Hi all;
Some fixing, and some making, today.
Doing some assembly work before getting started on the fire box, I couldn't figure out what the heck was
going on with this thing. I measured and re-measured everything trying to determine why things didn't fit.
Obviously, when the displacer is all the way down at the bottom of its stroke, it isn't going to fit inside
the hot cap. Well, it's supposed to!
Finally, I realized I'd measured the rod here from the top of the small cylinder that sticks out of the
displacer can. So, I drilled a new hole and cut off the excess, and tried it again.
Nope. The displacer didn't want to push off the hot cap any longer, but now the power piston and
displacer can hit each other as they go up and down in the bore.
Onto screw-up no. 2...
After looking at the same thing over and over on the prints, I see it. This thing is supposed to
go inside the can, and then measure from the top of the piece to locate the hole. I got that thing
out of the can, and of course, it had been put in with Loctite. Of course, when I put it back in the
right way 'round, the rod was too short. 'Cause I'd cut it off!!
So, make another rod.
Good grief.. No one will have to guess about it now. Proof I'm a goof.
Well, now things go round and round without pushing the hot cap off the bottom, or jamming
pistons in the middle. That's something!
I decided I liked the slimmer looking five spoke wheels, so faced them to the width I liked, then
drilled and tapped the hubs for set screws. Used lead shot in the holes so the set screws don't
scar up the crank shafts, making theses hard to get on and off. I've mentioned that before on
another build, but it's worth saying again. It will save someone a lot of trouble.
Finally making a start on the fire box, which also serves as a base for the main upper assembly.
This is the top most piece, where the cylinder will mount. Just a square of 1/8" CRS, drilled
and tapped for the mounting screws, and bored out in the middle so the hot cap can go through.
The boring head is one I made in the shop. I mention that because, yeah, I really enjoy making
my own shop tools, but I'd also like to recognize a nice fellow we have here on the forum. He's rather
quiet, so I'll toot his horn for him. He goes by "walnotr" here, and his name is Steve Campbell. He's
the fellow who designed and drew the prints for that boring head. He's also nice enough to offer
the prints at no charge. This is a perfect sized boring head for the Taig milling machine, and would
be good for Sherline and other smaller brands. I've used it for long enough now to know it's a very
good and sturdy design. I've said it before, Steve, but thanks again.
I have a link to the prints for the boring head for anyone who would like them.
Also cut out the ceramic fiber heat gaskets for the lower end of the engine.
That's it for today. Chasing after myself, fixing my own mistakes. It's better
than fixing someone else's. At least I know who to blame.
As always, thanks much for having a look.
Dean
Dean,
What's a couple of boo boos learning experiences. ::) ::) Great job and if I can keep my learning experiences at the same level as yours, I will be very happy.
Good stuff. :bow: :bow:
Best Regards
