Duplex Vacuum, (Heinrici type stirling)
Hoo boy. Time to drag this thread back from the dead and show a little more progress. I was
able to get into the shop a few times the past week, despite all the family doins'. Finding time
to get things written up in a timely fashion has suffered. I'll be able to get up a couple of posts
this week, before the next batch of visitors show up.
Last time, I had just received some new boring bars so I could continue hacking out the
pieces of the firebox. Then was interrupted for a bit. So, continuing on...
A bit slow going as the radius increased, and I went through two more cutters before
I was done. Kind of easy to crack the very edges of carbide on the interrupted cuts.
There are more holes to be done, and for the next set three of the pieces get a similar hole, so
once again they are sandwiched together and clamped to the mill table. Here, a wiggler is
being used to locate the punch mark for the holes.
If you don't have a wiggler, it's a tool worth buying. They're quite inexpensive, at about $15,
and pretty easy to learn to use. (The one I have was about $4, some years back)
They can be used to locate punch marks, holes, edges, and come with a DTI holder, too.
So, the holes are drilled and then bored to size with the boring head.
I was able to sharpen the two new carbide boring bars that I chipped previously by using a Dremel tool
with a small green wheel. One of the newly sharpened bars was used to finish boring these holes.
A piece of the firebox that goes to one side gets a ½" wide slot milled out so the burner
or lamp can slide in.
After some clean up with a file, I started the wiring job that will hold the parts steady
as they are soldered.
More in a couple of days, I think.
Once again, thanks for checking in!
Dean
I didn't know you could that. If it happens again a before/after pic would be helpful.
Thanks Dean.
Glad to see you're at it.
I like your step clamps. You made them yourself I assume. I just finished a tooling plate for my R/T, and was thinking about making some step clamps, but now I don't have to think anymore. :big: Thanks, hope ya don't mind.
Oh ya, one question about them. Aluminum Right? What "style" of aluminum is it? 6061, 7075?? I'm curious about the strength :shrug:, I suppose it don't need a death grip though.
Kel
PS. I would also like to see your Dremel method of sharpening boring bars. I need a better way than my bench grinder to sharpen tool bits. And tool grinders are spendy.
Thats quite the wire job impressive :big: :big: I like it!
If it happens again..? Rest easy, my friend. I excel at screwing up. It will happen again.
Doc, thanks. Kind of like wrapping a cat. Once you get it to hold still, you've got it.
Kel
Yes, shop made, Kel. 6061 if I remember right. Made them about 10-12 years ago when I had a Sherline setup. They've seen a lot of use.
They're plenty tough for what they do. I use 10-32 hard SHCS, and you will break those screws before bending the clamps.
Really, they're just simple copies of the commercial items you can buy, but being al, they won't scratch your work.
I'll mention the sharpening in another post. It's totally un-special. Give me a day to do some pics.
Thanks guys!
Dean
Dean,
It's a real pleasure to see your work. Thanks for posting.
Dennis
Welcome back Dean. As usual an excellent post. Wish I had a nickel for every brazed carbide boring bar or lathe bit that the students chip here. Most can be slavaged with the green wheel if just chipped, but the really bad ones are toast. Looking forward to more progress on your build and needing to give myself a swift kick in the backside to get busy again here.
Bill
Hi Dean, I lost track of this build and have been catching up. All is looking really good! Thanks for the props on the boring head BTW. It looks like you are getting more use out of it than I do. That may change now that a Whittle V8 is starting to get built. I will be cheating by using my CNC Taig instead of building up my arm muscles twisting cranks. Sometimes I wonder if the hand crank method would be better but then I make stupid math errors and am thankful the robot is doing the manual labor for me!
I'm looking forward to the end of your build and seeing this beauty run. :bow:
Zee and Kel, the carbide sharpening thing you were asking about is in a new thread in
the "Tips and Tricks" section.
Dennis, Bill, and Steve, thanks a lot for checking it out, and for the nice comments!
Steve, I pimp that little boring head every chance I get. I've used it quite a lot now, and am
convinced it's a solid design. The one post that shows it cutting the large half circle in the
firebox plates is a cut equaling a 2" diameter hole, and a heck of an interrupted cut, to boot.
The material was 1018 CRS, 1/2" thick with all the pieces stacked as they were.
It says something about Taig's product, but at the point where it's all hanging off the spindle,
that boring head is doing the work. Rigid and tough. You have a great design there, in my view.
Thanks again for the plans. I'm very pleased with it.
Dean
Soldering time.
Took me a little time to get all the pieces square to each other. I braided some wire as
Dennis showed in his Rudy Kouhoupt steam tractor thread. That's a good tip! In the past I've just
used straight single strands of tie wire for this kind of thing. Twisting a loop of wire into a braid
really helps the wire stay where you put it. Thanks, Dennis!
To start with the soldering, I did the top four corners, as the piece seemed happy to stay square while
sitting upright on it's feet. I'm not new at hard soldering, (silver brazing), but don't do it enough to be really
good at it. Still, I know how to make a decent joint. The four corners were pasted with a bit of flux,
and each corner got a small piece of 56% silver wire.
These are the hard solders I use. The 56% is BAg-7, and the 45% is BAg-5. If you are in the U.S., all
you need to know when you go to buy hard solder is the spec number. Ask for it by specification number,
and you will get the right stuff, no matter who makes it, whether it's from Harris, SRA, Eutectic, or
whom ever. It can say "Super Duper Easy Flow Extra Do-Da Day Solder" on the package, but if it has that
BAg-(X) spec on the pack, it will be the same as any other maker's Super Duper brand of solder that has
the same BAg-(X) spec.
The two solders I use are cadmium free.
The flux being used is Harris brand White Brazing Flux Paste. SRA also makes a white flux paste, and it works
the same as the Harris stuff. SRA calls their flux "601". There are other flux makers, but I can't remember
the names of them. Plumbers flux will not work for silver soldering. It burns up way before the solder
will melt.
To give an idea of how much solder is in an ounce, the thinner one in the pic has only had a few inches used
from it. It's .031" diameter and is what you get in an ounce. The thicker solder is .062", and has had a
good bit used from it. Probably about 1/2 ounce sitting there. I used about 6" in soldering up the firebox.
An ounce of .031" silver solder of most any type is around 20 feet long. An ounce of .062" silver wire has
a length of about five feet.
Regular hardware store type plumbers torches are used for the heating. I wasn't sure if these would get
hot enough for 1/8" steel on a piece this large, but they did okay. After the first few joints were done,
I substituted a bottle of MAPP gas for propane. It cut down the heating time noticeably.
The torch(s) you need depend on how large your work piece is, and the material it's made from. Steel is
not hard to keep at a soldering temperature. It holds heat pretty well. The thing is getting it up to
temp to begin with. The 1/8" sections being done here took a while to get up to soldering temperature, but
once one small area was to the point where solder started to flow, it was just a matter of chasing the joint
slowly with the torch flames and running the heat down the joint.
Copper and brass behave differently. They heat up fast, but the body of the work also wicks heat away at a
pretty fast rate. Ultimatley, the higest temperature your torch will produce is not so much the issue when
silver soldering. Even a tiny torch will make a 3000° flame, but it will be so small that it can't deal with
the convection that of the piece that pulls heat away from the joint. What you need is a large volume of
heat, rather than the peak temperature that would seem to make sense to us. A large soft flame will heat
a large area to a given temp and keep it there much better than a small intensely hot pinpoint flame.
Each corner was heated individually using one torch on the outside corner, and one torch flame playing
on the inside of the same corner. These were done with the 56% BAg-7 solder. The stuff I have is 1/16"
diameter, and each piece was sufficient to flow down the corner about ½". I used the 56% because it melts
down around 1150° f, which is about 200° less than the melting point of the 45% type. Even using 1/16"
diameter, it gets to flowing temp faster than the .031" diameter 45% that I have. The 56% costs
about $5 more per ounce than the 45%, but the lower melting temp is worth it. The two solders have a
similar strength, and both are suitable for copper, brass and other copper alloys, the various steels,
and other stuff I don't know about.
The bottom corners were done the same way, but the solder was put into the inside of the corner, since
I could get to that location with the torches easily. For these, I cut the pieces of solder about a
half inch long.
For each place you solder, as you heat the joint, the flux will start to bubble up, then the bubbles
will get dry and crusty looking before it goes liquid again. When it makes that crusty stuff, it often
pushes your piece of solder up a bit, raising it above the joint. Just poke it with a thin piece of wire
to put it back in place.
The reason the flux bubbles up is the water in it is boiling away. When the water has boiled away, it
is basically a mass of dry minerals and chemicals. This brings up a point that can be made here; If
you have paste flux that's been around a while, it will start to dry out, even though you keep the cap
on the jar. If it starts getting too thick and hard to brush on, you can add a little water to thin it
out enough to make it usable. That won't hurt it in any way. If you wait too long to re-moisten your
flux, it will eventually turn to a hard rock, and then you probably need to buy some new stuff.
When you see the flux go liquid, the heat is getting close. Watch your solder at that point. Shortly
before it starts to melt, it will start to get a shiny/wet look to it. Right after that, it will melt, and
sit in a puddle for a few seconds before it starts to flow. Keep your heat right on the joint 'til it flows.
If you are doing, say, a 1½" long joint, you would probably start heating at one end of the joint, and
when that end of your piece of solder starts to flow, move your heat along the joint slowly to get the
rest of the solder to follow suit.
If you have a gurt big torch, this will be easier, as the larger sections of the work piece will maintain
a flowing heat, and your solder will melt and get to flowing temperature all at once.
Once all the corners on top and bottom were soldered, I knew the piece wouldn't move and I got rid of the
wires. Then soldered down from the top about another inch and when the piece was cooled, mounted it on
the mill as in the pic above. The legs on the bottom were flat, but where the edges at the top met, it
was a little bumpy, so I took off .015" to make a nice flat place for the top plate.
To hold the top piece on for soldering, a rod is run through the arcs in the bottom, and a twisted wire loop
run up through the top hole.
Then a small rod is used to twist the wire loop until the top piece is tight against the base.
The piece of wire hooked to the right end of the rod is to keep it from un-winding.
This is where I'll leave off today. The flux is on the joint, a few pieces of solder sitting there
waiting for things to get hot.
Thanks for checking in.
Dean
Dean,
Another great tutorial! Thanks for posting. I'll be tuning in for the next exciting episode. :D
Dennis
Dean:
Lots of good tips in this thread... thanks! looking forward to more :big:
Cheers, Joe
Dean, again thank you. That was a very thorough expanation of silver soldering. I got lucky at the junk auction Tuesday evening and bought a Bernzomatic brazing torch for $1.00!!
I have work for the little beastie.
Thank you, guys! I appreciate your comments.
Mike, what do you have planned for your torch?
Dean
Another great post Dean, and a very nice looking base as well. Can't wait for the next installment.
Bill
Dean,
Thanks for the education. I seem to learn something from you every time your post.
Kind regards,
SAM
Thank you for this thread which I just found about yesterday...
Read it all, slowly, very enjoyable. Kept me up till 3 am this morning.
take care,
tom
I must say Dean nice job again!
I didn't realize that a propane torch would get hot enough to actually melt the silver solder. I have done very little silver soldering and most of the time it was been at my real job. But I have always use acetylene oxy.
I really like how you kept things together with the wire I would of been trying to clamp things together with clamps and usually it's a struggle. I see the wire approach really works nicely!
I LIKE!!
Bill, Sam, Tom, and Doc, thanks much for following along with all this stuff!
I left off with the top wired to the base, and flux and silver solder bits set in place. That was done
in four heats, similar to the other corners.
The next few paragraphs concern things that those of us who have experience "hard soldering",
(silver brazing) may find boring. Skip it if you like. People who are newer to "hard" soldering
may find something in it.
Something should be said about fluxing and pickling, maybe. The proper types of flux are discussed earlier,
but I didn't say anything about how much to use, or metal preparation. You need to have your metal pretty
clean, whether soldering steel or copper and its alloys, (brass, and etc.).
For steel, I just shine up the area that will form the joint with some fine wet or dry paper, or steel
wool. Don't use steel wool like you find in scouring pads, such as SOS pads. They're full of soap.
Use the kind you find in the painting section of the hardware store. After that, a quick wipe with a
paper towel moistened with a grease cutter, such as camp fuel, (naphtha).
For copper alloys, do it much the same, and a dunk in your pickle for a few minutes helps, too. Then rinse
it in water and dry your parts and solder them. After each heat, pickle the piece again to prepare for the
next soldering go 'round.
For a pickle, I just use ascorbic acid, which is also called citric acid, and often sold as vitamin C powder
in stores in the U.S. It's safe for your skin, and does a pretty good job of cleaning metals both before
and after soldering. I don't know a proper recipe for making ascorbic acid flux. It comes in 8 oz plastic
bottles in my area, and I mix one bottle of it with 2-3 quarts of warm water and dissolve it well. That
works, so that's how I do it.
After soldering, either steel, copper, or brass, I wait for a few minutes, then dunk the hot piece in the
pickle to clean the flux off. Sometimes it works quite fast, and sometimes it takes an hour or so before
I'm happy with the appearance of the piece. Scrub it with someone else's tooth brush if you have some stubborn
parts that don't want to come clean, Wash the piece in soapy water when it's done and rinse off well
to prepare it for the next heat.
I don't know a definite lifetime for the pickle. After it's used a little, it will turn yellowish-orange,
but it is still good as long as it's working within in a reasonable time. Ascorbic acid doesn't cost that
much, so when mine starts slowing down a little, I just make up a new batch. The same batch lasts me a few
months from the time I mixed it, depending on how often I use it.
Copper and brass seem to be more particular about being cleaned between heats than steel is.
For fluxing, when you put flux on your piece, more isn't always better, but it doesn't do any harm to the
joint. It will run around on your piece though, and some solder may want to follow it. You'll figure out
how much is enough. The thicker the joint, the more it will need.
If you can, flux the edges of the pieces to be joined before you assemble them for soldering, but don't
fret about it if you can't. If you have a number of joints to be done on a piece, you can't really flux the
individual edges, so just put it on the outside and carry on. Some folks put flux on the soldering wire as
well as on the joint. I can't tell that it makes a difference, really, as long as you are putting your bits
of solder right in the joint before you start your heat. Suit yourself on that point. We have our own
preferences.
After hard soldering the top piece, I filed off the little bits that ran outside the grooves. As can be seen,
I didn't get a flow quite to the corners on this edge. If it was a pressure vessel, it would need to be
re-heated for that bit, but this firebox is only going to be holding up an engine that weighs about a pound.
It will hold up a full grown man as it is, so I'll not be reheating it for that tiny bit.
I think the whole thing could have been done with soft solder, really, since I'm pretty sure it will not be getting
up to the temperatures that would be needed to melt soft wire, but I decided not to take chances. All the corners
at the top and bottom of the piece have now been hard soldered, and just for appearances, I'm going to fill
in the small spaces that would show up as lines when the piece is painted using regular solder.
I ran 96/4 tin/silver solder over all the joints to form slightly raised fillets, then filed everything off
flat. This is purely for cosmetic purposes, and does nothing to hold the piece together. A pretty easy
exercise with soft solder. It was fluxed right over the hard solder, and a soft flame on the propane torch
was applied until the flux 'browned', then run the soft solder over the joints at a temp that barely lets it
flow, so it piles up a little bit.
After all the corners are done like this, it's a pretty easy job to file everything flat. Soft solder files
very easily.
I fit up the engine assembly to the base and snugged up the mounting screws enough to seat the displacer cylinder
to the base of the engine cylinder to seal it and provide compression. The engine got hard to turn each time
I snugged up the screws. Finally I decided it was because the displacer can was rubbing on the inside of
the displacer cylinder. I had tested it before I soldered up the mounting plate to the firebox/base, and things
rotated as they should.
Maybe the plate on the top of the firebox had warped a bit when heating it for the hard solder. It did get really
hot, after all! So, back in the mill, which was still set up for this piece from the last milling step.
It was warped, all right. There was about .015 bow in it, which was causing the displacer cylinder to tip and bind
when I tightened down the engine assembly. A few passes with an end mill had things flat, once again.
That's it for this post. I know it's a lot of writing for only three pictures, but I had some 'splainin' to do.
Thanks to anyone who actually read all of it. Thanks to anyone who looked at the pictures. If you did both,
wow! Thanks twice!
Dean
Dean
You're welcome. Twice. :big: :big:
Cheers, Joe
