- May 27, 2010
- 2,999
- 1,171
Hi Paul,
Good Idea.
Proxxon sells adhesive stick on sanding disc. For now may use double sided tape or contact glue for testing.
Since I am only doing very light sanding to touch up and get the mitre angle,same same disc may last quite a few box life.
Sanding Machine done. Will wire up tomorrow and test run. Might as well set and lock up mitre joint angle.
For now going for the simplest grinding guide.
Have some instrument boxes to make. The sander is just in time.
Sander cost nothing using surplus material. Motor came from a friend.
Good Idea.
