Electrically, he also designed a generator - that looks a lot like the turbine -
Put a couple of magnets either side of a disc, spin it FAST and the outer edge develops a high DC voltage compared to the shaft. The difficulty is gathering the CURRENT from a brush on the outer rim of the disc.... it overheats with friction. But if you put a pair of these disc generators together, just touching at the rim so they are contra-rotating at the same speed, and have the same direction of magnetic flux, because the contact is stationary it does not overheat from friction, yet the electrical potential of one disc is reversed in the contra-rotating disc, hence the shaft-to-shaft potential is double the across-disc potential. Fancy making one? Maybe I should? - It was designed to use the high speed of his turbine... but materials and bearings failed due to materials and manufacturing accuracy at the time of Tesla.
Then there was a guy called Wurtz - designed an odd pump.
Fun and rubbish off the web? (The rubbish is mine).
