Thanks Toymaker, yes I remember which project this is now. Just observations, as I am no expert on Flash boilers! (Or any other boilers. But I have repaired more than I have made, and only about a dozen in total. - including scrapping BAD designs.).
I have done some boiler calculations, and as there are also University research papers, etc. on the calculations, have "an opinion" of what I think is a "safe" limit for Model Engineers.
I realise your boiler is beyond being just a model, and as such suggest that the ASME boiler limits (for stress and temperature for steam boilers, etc.) are reasonable - to avoid catastrophic failures. I also understand that the Chemical nuclear and rocket industries always do their own thing, because they have the money, people, etc. to prove what they are doing is safe... - ish. I wonder if NASA thinking 1% failure rate of rockets in the 1960s would pass judgement today? But their pressure vessels and systems are not known to have failed in normal use. And at times of War, all things are driven to extremes, so higher stresses are used everywhere... So ASME doesn't cover all scenarios.
But musings aside:
ASME (A bunch of clever American engineers who are trying to protect people from the law courts) suggest that "Silver-Soldered copper boilers do not exceed 100psi" = 205deg.C.
Although I reckon there are a lot of boilers made to "old" designs that exceed this - e.g. in the UK there are many older locos with copper boilers and superheater tubes at more than 100psi. 205C. - It is recognised that these do not relate to today's perspective of ASME regulations in the USA, or equivalent in Australia, etc...
BUT this (ASME Regulations) allows (effectively) for a Factor of safety of 8 on yield stress at elevated temperature, but it also includes for various stress concentration factors of various shapes of stressed boiler parts to be considered in the design calculations. (Stress concentrations can be the "killer" in many designs).
In conclusion, I am sure you will have considered many things in your flash boiler design, but using copper at 400psi may be working a bit closer to the limit than most would consider safe. While some say the max safe working stress for copper is around 6300psi. at <60C, at 205C (100 psi) this is de-rated to about 3000psi for the SAFE tensile stress limit. I do not have a tensile stress limit at 243C, but assume this must be significantly below 3000psi. Added to which, the making of a flash boiler using bent tubing will create thinner zones of material, and some local stress raisers? - You know your design, so I hope you have confirmed any stress concentration factors and appropriate wall thinning stress concentrations in your calculations.
While "Flash" boilers contain MUCH less water than "Conventional" boilers (as covered by ASME etc.), your boiler can still have many lbs of hot copper, hot water, and steam, in a confined space with a powerful burner, so still poses some risk (from escaping steam, etc?) in the event of failure (eg. a burst tube). So please be careful with your design, and try and consider all the things that could possible go wrong before working it up to your planned working pressure. I am the far side of the planet, so unlikely to hear screams from Thailand. I prefer there to be only screams of delight!
Also, I wonder what material you have used for the plates of the Tesla Turbine, as Tesla had severe problems of distortion (Caused by Differential expansion due to the temperature change across the plates?) with his turbines, exacerbated by the centrifugal stresses at very high speed. 160000rpm sounds a bit high for "normal" materials?
I have been trying to run at the other end of the scale: The Tesla Turbine is only about 3in diameter, and the steam supply is limited (I only have a little boiler available for this!) so I am running at 30psi, with little superheat, and getting 20000rpm free-running. The exhaust steam is very wet, but when hot it seems to not have residual water inside the turbine, but I needed to add a tiny drain hole in the casing to expel water during cold starting and warm-up phases. Otherwise it simply became a condenser half-full of water...
"Good luck" = wrong... I truly wish you to be a Good Engineer and not have need of luck with this one.
