Linz
Active Member
Here is the speed control board (aka a dc drive). It's function is to covert the 110vac to 90vdc. Line voltage is fed in via terminals 24 and 14 on the magnetic start switch to L1, L2 on the control board. Output is controlled by the pot connected to the P1, P2 and P3 terminals and output on the A+ and A- terminals on the board to terminals 5 and 7 on the forward/reverse switch and from the switch to the motor via terminals 6 on 2. The f/r switch just reverses the 5,7 connections to the 6,2 motor output for operation in opposite direction. Made by KB Electronics in Florida. KBLC-240D. Believe it is the same used in the cx601 mill. Makes sense, it's the same motor. I don't think they make these anymore although the current KBIC-240D is almost identical. These sell through various vendors in the US for $92usd + exchange rate + shipping. You may be able to source locally, there
is a place in Edmonton that sells them for $172cad + gst.
