Thanks Paul. And I had been taught it was "smoke leaking out" that caused all the electronics to stop working. Maybe the gel is condensed smoke? I have seen sticky stuff that has bled from dry cells when they have died... but not from capacitors.
The 2 types of capacitors made in a factory where I worked as a young engineer were high voltage types for phase correction on long overhead power lines, that used paper and oil insulation with aluminium foil plates, and the other sort used polymer insulation and foil wrapped in aluminium cans for fluorescent lamp-ballast inductive compensation. None of these were filled with smoke, so I assumed it was diodes and transistors full of smoke that could leak and fail. I have had a good few of those in devices I have owned. Especially thryristors. They can get quite hot when the smoke leaks out of them....
