Richard Hed
- Nov 23, 2018
- 2,792
- 755
My piece of metal is oversized by about 1/4" so I put it in a 3 jaw with a live end. I have the piece sticking out long enough to make TWO pieces as I need two. As I said before, I thimpfk this is really a poor design for this input steam valve, however, I, like yourself, want to make it to the specs of the machine. I don't make all my pieces to the exact specs but most of them.Now I'm starting the steam inlet valve, the plans for which are ataached.View attachment 152462View attachment 152463View attachment 152464View attachment 152465 It is a secondary part which is not involved in the good functioning of the engine. However, and given my somewhat perfectionist side, I will do everything I can to create the piece as faithfully as possible. I will post the progress step by step.
I start with a solid 30mm stainless steel bar. I took it in a chuck with 4 independent jaws, first to have perfect centering, then because the jaws are longer than on a standard 3 jaw. I first made two cuts corresponding to the lower part of the roundings. The spherical part was used very well in 4 steps and as many changes in tool position. But the connections are very well.
LeZap
I'll try to take a couple photos later.
