Your welcome!Nice house and Corliss !!!
I think we need to come visit you.
So now you have moved and retired. How is your Coles coming?Hello everybody,
I will retire at the end of April '23.
But, I'm going to move to the south of France in Nice Côte d'Azur. But it's 715 miles from home. (1150Km)
And every month, I move a full LT of goods, furnitures, workshop, etc...
It's very hard to move and at the same time do my job of technical manager in one of the biggest Belgian Trucks Cy.
At the end, it's a lot of job. So, be patient, I will be back soon.
Attached file, my future workshop in progress
LeZap
View attachment 144030View attachment 144032
I take it that Enedis is the power company? Can you use a VFD?Yes, I'm now living in Nice since one month.
But I'm facing an other problem. All my machine use 3X380V, but i've only single fase 220V.
And I'm fighting with EDF/ Enedis to have 3X380V.
It's very complicate in France to get this! It's dominant position of state company. Hegenomy with other words
Regard
LeZap
EDF is the electric supplier (Electricité de France)I take it that Enedis is the power company? Can you use a VFD?
Yes, thanks, I know this solution. But it will be a problem with my Atlas Copco compressor.Hmmm. I should consider a single phase to 3-phase voltage converter/speed controller... if you can buy such a thing? I once considered buying a Drilling/milling machine that had been "converted" to remove the single phase 240V motor and multiple pulleys... and replace with a single pulley and 3-phase motor driven by a single phase to 3-phase variable speed controller.... (The Electrical Engineer didn't realise the loss of torque at the quill at low speeds of the motor compared to the speed reduction by multiple pulleys! - It saved him doing belt speed changes, but he was selling the machine because of the poor low speed performance with larger diameter tools and heavy cuts, afterwards!).
https://www.ebay.co.uk/itm/19488394...it1aCkkAg86uuhOBTJHCVIhW0BU=|tkp:BFBM4NfIjaBi
Search: Frequency Converter Single-Phase 220V To 3-Phase 380V Motor
Perhaps cheaper than a new supply from the Utility?
Of course, you're welcome. There is a large british community in Nice.LeZap.... Are you accepting visitors? - I like to visit Nice! Warm and sunny compared to the North-East of England!
In my experience, this is the most common use for a VFD especially for hobbyists. When I was younger (last week) an aquaintance wanted to have 3 phase wired to his house. This is about 40 years ago, the cost would have been 10,000USD in that years dollar value. An expensive VFD can cost 1000USD but a cheapo like the one I have is 90USD. I'm sure the one needed for Frawhnce would be in the mid range somewhere. After all it appears to be really odd voltage there.I think I have seen several hobby folks using VFD's on each piece of 3-phase equipment, in lieu of a central phase converter that serves all of the 3-phase equipment.
So the VFD would be single-phase in, and 3-phase out.
Check with the folks who have used this method, and verify that this is working for them.
Can anyone comment on this method?
380/3/50 is common outside the US (460 x 50 / 60 = 383.3333etc). 460/3/60 motors will run, but 17% slower (which can be an issue with fan cooled motors).In my experience, this is the most common use for a VFD especially for hobbyists. When I was younger (last week) an aquaintance wanted to have 3 phase wired to his house. This is about 40 years ago, the cost would have been 10,000USD in that years dollar value. An expensive VFD can cost 1000USD but a cheapo like the one I have is 90USD. I'm sure the one needed for Frawhnce would be in the mid range somewhere. After all it appears to be really odd voltage there.
Haven't done- - - - looking/reading - - - anything over small motors (think that was like 1 kW / 1 hp) the requirement when using the vfd to add the third leg was to de-rate the vfd to 58% of nominal capacity. So for a 7.5 hp motor you would need to run a vfd for a 10 hp.I think I have seen several hobby folks using VFD's on each piece of 3-phase equipment, in lieu of a central phase converter that serves all of the 3-phase equipment.
Is your property in a restricted zoning area?Yes, I'm now living in Nice since one month.
Regard
LeZap
Yippee yippee - - - - is the chez Zapjack also open (giggling)?Hello friends, ater moving to the Côte d'Azur (french riviera)
I'm back in my workshop!
LZ
Simply use a inverter/ converter 220V to 380V buy on aliexpress at 150€So what did you do re: your power requirements?
I recognize all those parts except for the little nipple one at top left. What is that?some parts from the governor. all are made from bar stock steel
LZView attachment 151686
