and the finished connecting rod.
Do you have a photo? Am not exactly sure what you mean.Your engine is looking great! I'm building the same engine and cringed at the thought of milling the 1/16" wide slot 1/4" deep in the steam valves, so I cheated and drilled a series of 1/16" holes as close together as possible. I think this will allow plenty of steam throughput; time will tell!
Richard,Do you have a photo? Am not exactly sure what you mean.
Dave,Richard,
Here's an exhaust valve (with through slot) and a steam valve (with 1/16" holes). I forgot that I milled a 1/16" wide slot about 1/16" deep to match up with the slot in the cylinder, hoping this would leave the valve timing unaffected by he use of holes in place of a slot all the way through.
Richard,Dave,
I too am working on this Corliss. I'm wondering why you have put 1/16th " slots for the valve stem on both ends. This might cause friction when running. Also, am curious if that exhaust valve has a slot the length of the valve? It llooks like it but might just be the photo. What about the side with the slanted section? What is that called anyway? That part, especially on the exhaust will be verhy difficul;t for me to do. However, I managed to get some extra CI incase I blow one or two.
LOL, yeah, that's why I found some extra CI. Yes, I thimpfks I saw a drawing like that with the slots on both ends but I don't have them on mine (me thimpfks).Richard,
I'll admit, these things were a pain the neck. Of course, the "slots" I was referring to in my earlier post were for the passage of steam (and exhaust). As for the slots on the ends of the valves, one end is to drive the valve. The slot on the other end is in the drawings and is, I believe, used for assembly and/or timing purposes; it does nothing once everything is assembled and running.
I was able to but the slot all the way through the exhaust valve because this one is 1/8" wide, so not to unreasonably thin. Oh, and I should say, I did trash one steam valve when I was almost finished with it. Argh!!!
Do you have a rotary table? That would make cutting those bevels on the valves a WHOLE lot easier. Am not sure how I'm going to do it, don't have a rotary. Am working slowly on building a rotary but so far . . . .
Anyway keep us up[ on your work with lots oif photos.
Dave, I used a 1/16" wide, small diameter slitting saw in the mill and finished the ends with a jewelers file.Your engine is looking great! I'm building the same engine and cringed at the thought of milling the 1/16" wide slot 1/4" deep in the steam valves, so I cheated and drilled a series of 1/16" holes as close together as possible. I think this will allow plenty of steam throughput; time will tell!
did you use the slitting saw to cut out the bevels?Dave, I used a 1/16" wide, small diameter slitting saw in the mill and finished the ends with a jewelers file.
The valve was not trimmed to length and in a spin index. Don’t remember for sure but think I used an end mill. I’ll try and find pictures.did you use the slitting saw to cut out the bevels?
Attached is photo of slitting saw operation and it looks like I used end mill for bevels, this was 4 years ago and my memory isn't serving me well. The third photo shows finished valves, note I cut a small groove in each end to serve as an air seal for blow by.The valve was not trimmed to length and in a spin index. Don’t remember for sure but think I used an end mill. I’ll try and find pictures.
THAT is FERY een-tehr-resteenk! What a very clever method. However, I'm curious why you built in a "blow by" groove. Won't that cause leakage?Attached is photo of slitting saw operation and it looks like I used end mill for bevels, this was 4 years ago and my memory isn't serving me well. The third photo shows finished valves, note I cut a small groove in each end to serve as an air seal for blow by.
The blow by groove actually improves sealing. Any flow causes a turbulence, which acts somewhat as an air seal.THAT is FERY een-tehr-resteenk! What a very clever method. However, I'm curious why you built in a "blow by" groove. Won't that cause leakage?
Are those CI? They look more like steel.
I understand the theory, but it is rather difficult for me to visualize.The blow by groove actually improves sealing. Any flow causes a turbulence, which acts somewhat as an air seal.
I used 12L14 precision stock from McMaster Carr.
bonne idée !, je vais suivre ta suggestion, mais en terminant avec une fraise en boutRichard,
Voici une soupape d'échappement (avec fente traversante) et une soupape de vapeur (avec des trous de 1/16"). J'ai oublié que j'ai fraisé une fente de 1/16" de large et d'environ 1/16" de profondeur pour correspondre à la fente du cylindre, en espérant que cela laisserait le calage des soupapes inchangé par l'utilisation de trous à la place d'une fente tout au long.
Well, Look at that, it proves the French do not have a word for "entrepreneur".bonne idée !, je vais suivre ta suggestion, mais en terminant avec une fraise en bout
LeZap
