HOW you make parts does matter depending on your view on the model, your leisure time, personal build up, experience and the knowledge and ability to learn.
If anyone expects that they can go out and build or buy a machine load a code and it spits a perfect part out is in for a shock.
Just as when you were first let loose on a lathe you didn't do an internal multi start thread did you ?
Chances are the first few threads you did were crap - mine were
Just as making a run of parts on a turret or capstan lathe will differ in setup and operation from making 10 one off on a centre lathe so will learning to operate a CNC.
For a start a lot of the important work on a CNC is done away from the machine [ hint extra play time whilst inside with her indoors ] For some this becomes an extension of their hobby. Speeds and feeds are very important, there is no 'feel' on a CNC so you have to understand this more so than working manually.
We should be able to understand feeds and speeds as it is but like many you can get away with 'feel' and sticking your tongue out the side of your mouth makes up for a lot of short comings .
Then we get onto holding methods, again probably totally alien to how you would do it manually.
Take a crank web, manually you would drill and ream the two shaft holes then using a pin in a rotary table you would mill the radius then reclamp and mill the outer web shape in anything from 3 to 7 settings.
On a CNC the quickest way would be to mount a piece of round bar vertically in an old chuck on the bed. Rough the holes, rough round the outside then finish the outside and the holes in one pass at full depth, climb milling all the way for a smooth cut, then part the slice off in the lathe or even two slices if needed.
The skill is still there but it's a different skill.
I recently made this:-
It's a selector cam out of a racing bike gearbox, can you imagine the amount of jigging and special tools, followers etc needed to make this ? Fine for industry when they were making 1,000's but this was a one off and not even a copy.
Worse it didn't work as required and the second one had a different profile on the last cam to stop it clouting the 4/5 gear.
There was absolutely no difference in the setup between the MKI and the MKII
60 Years ago most home shops had a lathe and possibly a drilling machine - period. When I first got interested in home shop engineering no one I knew had a mill, everything was done on the lathe.
Slowly mills came in to supplement the lathe. CNC's will be no different. They won't take over but will be there to supplement existing tooling.
CNC Mills are very adaptable.
Not got a 1" x 20 tap for that special job and it too lopsided to go in the lathe ? Simple take an old broken 3/8" BSF tap grind all but 1 flute away and you now have a thread mill.
Drop it in the hole, start up, move the the side of the hole and do one circle lifting the tool 1 pitch as it goes round.
Perfect thread in one pass and that tool will do ANY 20 tpi thread it can fit into or even thread the outside of a shaft in one pass.
Want a nice flowing shape for a carburettor body and a form tool will be too wide and chatter if you can grind a nice enough shape ?
Simple bolt you lathe toolpost to the mill bed, stick the carb body in a holder in the spindle and switch on. You now have a CNC vertical turning lathe.
Change the tool for a boring bar sticking vertical and you can form the inside shape to get a uniform wall thickness.
Same part - different skills.
