What do you think of using PEEK for the spark plug insulators? Corian is pretty much impossible to find, especially with many businesses closed these days. So I bought a piece of PEEK. It is not expensive for the size needed here ($6 from McMaster-Carr for more than enough). I broke the first attempt, but the second one worked well. Easy to machine, slightly flexible. It is supposed to be good to temperatures higher than Corian can take. So I've made one spark plug....not perfect, but I'm pretty happy with it. I'd hate to make 7 more only to find out later that I shouldn't have used it.
One other question. What should the gap be for the spark plug? The plans use the tolerance of all the pieces to end up with a gap, but in case I've got things off a little, I can bend the outer electrode to adjust it. I suppose I can go through the plans and assume everything is dead-on and see what the gap should be, but how critical is it with the ignition system it uses?
thank you,
Rick
