I am not aware of that problem, although it may be unique to melting in a crucible with flame. What you had to say is true of ductile iron, however, where the window of opportunity to pour the inoculated metal is relatively short.
That's not true. Nodules are not formed in gray iron, nor in white iron. Nodules are formed when gray iron, low in sulfur, is inoculated with a magnesium (or other) inoculant. Glomag is one that is readily available. Gray iron precipitates free graphite in the form of flakes, which is the chief difference between ductile (nodules) and gray iron. Aside from the need for lower sulfur, ductile and gray are pretty much otherwise identical chemically.
Gray iron is often treated with calcium carbide to lower sulfur content so it can be converted to ductile. American States Cast Iron Pipe, in Utah, does exactly that, melting with a 96" water cooled cupola. I had a tour of their facility in the early 90's to witness their operation. Fascinating to see large pipe poured in 20' lengths in water cooled permanent molds. The pipe was removed and sent to annealing ovens in huge racks, as the water cooled molds instantly chilled the pipe.
Old Gold
I think I am mixing my metaphors in my statement about "forming nodules".
The correct statement would be "forming graphite flakes".
I am just getting into researching ductile iron, and so still learning the correct terminology.
I would love to have an induction melter, but alas I am stuck with a "poor-man's induction furnace", which is an oil-fired furnace.
Induction motors generally pull six times their rated amperage when starting, and if they are started under load, perhaps more than that, or perhaps the same amount for a longer period.
One definitely does not need a quick instantaneous setting on a circuit with heavy motor starting.
I have been on a quest (like a Holy Grail type thing) to make ductile iron crankshafts, and I cannot get anyone to sell me a reasonable amount of nickle-mag additive. I have begged more than a few people for some of it, to no avail.
I even have the calcium carbide that I need, but no nickle-mag.
The center of the iron pipe industry was just a few states over from here (Birmingham Alabama to be exact), and there is still a lot of foundry activity in Alabama, as well as a large coke industry.
I initially thought I would melt iron with coke, but I could not find a source for that either.
In the end, I am glad I went with an oil-fired furnace, since it is an easy one-person operation, even if hundreds of pounds of iron are poured (using a pouring cart).
You have any photos of your furnace/pouring operation?
That sounds interesting to say the least.
