Hallo everyone,
as fabulous George has started this very informative article about carburators some weeks ago I like to show you the new carb version I have designed a month ago for my latest 0.25 cubic inch 4-cycle gasoline driven engine.
My first version was a simple carb like the radio control people use on there methanol engines. I was inpatient and wanted to get the engine running, so I wasnt in the mood for long experiments and complex extra craftsmanship on this marginal component, but this was far wrong
.ha ha ha
The main dimensions are 6mm (0.24in) of free air passage and a reduced venturi area of 4.8mm bore (0.19in) in the rotating barrel type throttle.
I didnt last long to notice, that this arrangement was not the first choice for my need. Okay, the engine started from time to time, but it doesnt want to run longer than 20 seconds or so and it showed a lousy idle behaviour. Additional the gasoline level had a prominent influence on the whole function, being to low starting was nearly impossible, hanging the reservoir too high means the permanent danger of over floating the intake area.
Okay, to get at least any results with the existing material I tried to modify the venturi area. I made the fuel jet cylinder larger in diameter (from 2.4 up to 3mm) and let it now reach completely into the other side of the throttle barrel which means a quite heavy reduction of free section.
As George already mentioned, we tend to oversize the intake dimensions of our little gasoline motors, especially when we refer to comparable methanol engines. So, with this reduced width my engine was running a lot better. Suddenly I was able to speed up over 7000 rpm, could make long runs of 10 minutes ore more and the idle control was bearable too.
What left was a quite lousy starting behaviour, sometimes immediately running and then on other times it could drive me crazy, and the old problems with the influence of gasoline level.
My idea was that especially for the starting procedure the fuel jet needs the right fuel pressure. As the intake volume has only a small amount the vacuum from the venturi is too weak for the right starting mixture. It seems, that venturi proportions which are suitable for full throttle run dont work good for starting the engine at nearly idle setting. There is simply too little sucking on the fuel passages.
Okay, about three months after finishing the main engine I designed a complete new carburator
.ha ha ha
The new one is a mixture of a simple motorcycle type and a two needle methanol motor carb. It has a sliding barrel type throttle which contains the linear travelling idle needle and it got a float chamber too.
It took me some time to decide about the free section dimension. First of all, the intake ways of my engine should remain as they are. Second, I would like to use the carb on my next motor which will get a slightly larger displacement (at least for the first testing). So I made a 6mm (0.24in) main bore again with a venturi restriction to 5mm (0.2in). My thought was, that with a sliding barrel, the shape of the gas passage could still work well, even if the throttle is only half way (or three quarter) open at full speed.
Here comes the inner life of my construction:
From the float needle valve the fuel flows through the float chamber and reaches the main body from underneath into an upright channel which contains the main mixture needle on its top. This needle has a 10deg cone and is driven by a fine pitch screw for a sensitive regulation.
From the main needle it goes over to the backside of the fuel jet tube. This little, single tube is held by a plug screw and easy exchangeable for further experiments with its functional proportions. All parts are sealed with o-rings, only a little bit more effort while building it, but no more problems with fuel and (more important because hard to detect) air leakage afterwards.
The remaining part is the sliding barrel type throttle valve, it goes with 6mm (0.24in) diameter through the 5mm (0.2in) venturi bore. The idle and half speed needle is also easy exchangeable, it is obvious that this needle might need a lot of experimenting to find the right shape and dimension later on.
End of part one
